Whenever I start feeling a little too geeky for hanging out here at Radioreference, I just visit the CandlePower Forums for a few minutes, and suddenly I feel 'normal' again.
The Refresh mode. It will put your batteries through a discharge - recharge cycle. Noting the battery(s) voltage and amperage after each pass. It will continue the cycle until the battery(s) show no further improvement.
FYI: For general everyday use I pick the Discharge mode. Both Whistler and Uniden by design set their Low Battery Warning Levels at a very conservative and safe point. The batteries typically still have a decent charge left in them. By selecting Discharge, the batteries are more completely discharged then fully recharged. This reduces or lessens the need to due frequent Refreshes. It all depends on your use.
The manual for the La Crosse is very easy to read. It does a good job explaining the various mode settings.
I thought I read the LaCrosse only supported higher charge rates when only slots 1 and 4 were in use. There also appears to be a max of something like 3A output if I recall what I read on that model.
For 2400 mah batteries I think you would be plenty safe at the 500 ma charge rate. I typically stick to one third of the rating of the cell or lower, the lower the better.
I am not familiar with the LaCrosse chargers. Maybe someone else that owns one on here can help with your question on the mAh display. However, I will also suggest you register at CP and you can post there what you posted here, I can almost guarantee you will get the answers you seek.
On your charging question in post #22 about the recommended charge current for NiMH batteries, I was directed by the folks at CP to this chart/table to charge and discharge my batteries. It is what is recommended by most battery and battery charger manufacturers:
The recommended charging current is 0.5C, or 0.5 times the battery capacity. The recommended discharging current is 0.25C, or 0.25C times the battery capacity. Here are some settings for common batteries:
2700mAh Charge: 1300mA Discharge: 700mA
2650mAh Charge: 1300mA Discharge: 700mA
2500mAh Charge: 1200mA Discharge: 600mA
2300mAh Charge: 1100mA Discharge: 600mA
2200mAh Charge: 1100mA Discharge: 600mA
2100mAh Charge: 1000mA Discharge: 500mA
2000mAh Charge: 1000mA Discharge: 500mA
1000mAh Charge: 500mA Discharge: 200mA
900mAh Charge: 400mA Discharge: 200mA
850mAh Charge: 400mA Discharge: 200mA
800mAh Charge: 400mA Discharge: 200mA
700mAh Charge: 300mA Discharge: 200mA
650mAh Charge: 300mA Discharge: 200mA
600mAh Charge: 300mA Discharge: 200mA
Furthermore, if you want to learn more about batteries in general I would recommend this site:
Basic to Advanced Battery Information from Battery University
Yes, I ordered and have their book and I promise you I have a life....LOL! I have not read it yet though, due to getting into ham radio shortly after ordering it and being preoccupied with getting my tickets and learning everything I can about ham.
Hope this helps.
Thank you. So after reading more it says once it hits 2000 mAh it goes to Ah and adds a decimal due to room on display.
It also says if display shows 000 mA in charging mode it's because it got hot and is cooling. Mine did this a few minutes ago. Is this normal or do you think I have a defective one?
I'm debating on returning it and getting the c9000 but from reading NLee reviews you have to push about 40 button pushes to do a refresh of 4 batteries.
Do you feel you have to do a lot with the c9000?
I do not personally know NLee nor I have I interacted with him, but my research has led me to believe he has a basis towards certain manufactures....take that how you will.
As far as the C9000 and button pushes, in my opinion he greatly exaggerated it. I am currently charging a quad of Duracells and it literally took me less than a minute to program my charging rates and that was inserting one cell at a time and documenting each individual IR reading (Ok maybe I don't have a life.)
Either way, the button pushing aspect is blown way out of proportion by some in my opinion. I am sure there are other C9000 owners on here that can give there own assessments on that if they want. For me its a non-issue.
Here is the main issue with the Lacrosse design....there is hardly no spacing in-between the charge slots, which leads to (at times) a large amount of heat being generated within the charger.....Unlike the C9000 which has good spacing and thus allows for excellent heat dissipation. It was one of the main reasons I did not go with the Lacrosse charger. If there is one thing I have learned from my battery knowledge quest, is that heat is most harmful danger to NiMH batteries. Heat is no bueno for NiMH!
Very bad things can happen to overheated NiMH batteries....
Has your c9000 ever paused due to heat? Also can the display light be turned off at will it does it stay on all the time?
It has never paused due to heat.
The light can not be turned off. It stays on as long as there is a cell inserted in a charge slot. Yes, its bright, but I like it.
My wife, not so much, so I eventually took it out of the bedroom and now its part of my shack.![]()
Interesting review. I have the IQ328. I never realized it was a clone of the BC1000. I have never had a thermal problem with it, but I have never used anything higher than 700ma to charge my 2300mah RS batteries. Works fine for me. I did have one battery one time that displayed null, but a short time in my RS charger "fixed" it.
So would you return bc1000 and get the c9000?
I could tape part of index card to it to flip over at night to block the light.
That's going to be up to you. You have a good charger and I am sure many folks that own it like it, I just happen to like mine, without ever having owned or tried the BC1000.
Yes, many people use something to cover the screen with on the C9000 to avoid the brightness if they so desire.
At the end of the day, its like ham radio....I could tell Yaseu makes the best radios, but you or the next the guy may say its Kenwood or Icom.![]()
Shoot, I just got a Diamond SRH77CA antenna for my HT, I am disappointed that it does not screw on all the way to the bottom of the antenna connecter and instead leaves a small space. Read where one guy returned it and got a Comet SMA 24 instead, which is rated better then the 77 on eham.....My plan is to keep the Diamond and make do. Maybe I'll go to the Comet or something else later down the road. Besides, anything is better then the rubber duck that came with the radio.
Battery chargers are kind of the same way. Anything that charges "smart", is better then a "dumb" Wally World wall-wart charger...![]()
I understand. I may try this for a few more days. It's been like this for the last 3 hours. Not sure what's going on with the last battery. Numbers haven't changed on last battery either.
Since you're running a Discharge/Refresh cycle, it's most likely the one on the right had not stopped improving on the last cycle. The charger determined the other three were as good as they were going to get after the last cycle and stopped. The remaining one needed another cycle. Have faith, it will finish.
