Some info regarding where in Canada you are, your primary monitoring interests, specific system(s) you intend to monitor primarily, etc would go a long way in helping us help you make a recommendation for an upgrade. Sure you could go big or go home with an SDS200 but If
simulcast distortion isn't a factor, or your area is primarily analog or P25 Phase-I then the SDS200 may be overkill & you can save hundreds by buying a non-SDS model. But if money isn't an issue, definitely go with the SDS200. I own its handheld variant, the SDS100 and it doesn't miss a beat on anything I monitor (and that's a whole lot).
Best of 73's to you & good luck with whatever you decide to purchase
