aRadarLove
Please, What is the Best Uniden digital scanner of 2020. The one or several that covers all bands and trunking? Thank you. Danny dan22x@aol.com
No scanner covers "all bands". Some questions for you to consider would be what are your primary monitoring interests? Do some research on the Radioreference database to determine what type of trunked system(s) you primarily intend to monitor. Focus on the "System Type" row.The one or several that covers all bands
If I had a dollar for every "best scanner" or "favorite scanner" thread created on these forums I'd be a rich man. Of course the general consensus are the SDS100 & 200 but I'd be hesitant to make that recommendation if simulcast distortion isn't a major factor in your area or if the agency(ies) of your interest are still analog. If it's within your budget, then go for either SDS
Does encryption exist on the system(s) and talkgroups of your interest? This would be denoted in the Mode column of each talkgroup as 'De' or 'Te' (lower-case 'e' indicates part-time encryption) or DE or TE (capital-E indicates full-time encryption, which no scanner can monitor) Widespread encryption can greatly influence one's decision on whether or not to purchase a scanner
Once you do some research and know the answers to these questions, this will give you a better idea of what scanner to buy. Maybe check with the folks on your state forum to see what they recommend for your area. The chart below summarizes trunking scanners and P25 system types they can track. Perhaps this will be of great use to you:
Best wishes!
So Danny if your question is what's the best digital scanner Uniden makes in 2020 for me then there are a lot of factors as been mentioned here. What your needs are, price point EtcDanny, no one can correctly assume or guess your wants and needs as far as your monitoring interests without knowing your logistics and location and the agencies you wish to listen to. The quick, uninformed, reply would be the SDS-series scanners if you have simulcast LSM in your area, the SDS100 handheld or the SDS200 base station. If not, then the Uniden BCD536HP and BCD436HP would be better suited for your situation.
If you need to pick up the New York State Police simulcast
Uh, he lives in troop D and the database says that's a phase 2 Central New York interop system. Troop D also uses Phase 1 Lewis County system.Uh, which NYSP simulcast? NYSP uses analog VHF in most counties, unless they are on that county's TRS. There is no state-wide system in NY.
I live in Pennsylvania, I was only trying to help him out here but... why don't you take care of it since you know more about it.
And his or her location.The one that does what the buyer wants it to do at his price point.
Yeah, what I said.
Troop D covers seven counties in NY. Where there is a TRS, they operate on it. Neither of those systems covers Herkimer County.
Well perspective owner Skynet is under the impression that the state police are on Phase 1 and Phase 2 in Herkimer County so you have set him straight now.I too am looking at either the sds100 or the 436, I am in the 13350 area and know that the state police use P25 I & II mode FMN. Will the SDS pick up local PD as well?
I guess I assumed if he bought a scanner it would be at his location. My BADAnd his or her location.
Greg
I knew somebody might misunderstand that.I guess I assumed if he bought a scanner it would be at his location. My BAD
Yep I understand. The use of the filters or should I say the proper use of the filters makes a big difference. After mastering the 100 and 200 I have to say it is far superior than any other Uniden radio and I've owned them all.My 2 BCD996P2's are pulling in more than the SDS200, when I test on the same P25 Phase 2 Digital systems on the same antenna, a Yagi.
My 2 BCD996P2's and BCT15x are pulling in more than the SDS200 when I test on the same VHF/UHF Analog systems on the same antenna, a Diamond Discone.
I have no Simulcast issues, at this time, but still have an SDS200. I like the features on it.
Thanks everyone for your replies, didn’t mean to hijack this thread. For me it’s was a simple question of will the SDS100 work for me or am I wasting my money? Sorry again for going OT!
