prcguy
- Joined
- Jun 30, 2006
- Messages
- 17,609
- Reaction score
- 12,921
What you made is roughly what the Comet 250B is but a little longer. Not a very good antenna even for HOA use.
prcguy
prcguy
Get an MFJ1910 33 ft push up pole. 33ft of #14 awg wire, A Balun Design Model 3132 9:1 balun and an MFJ 915 Isolator along with about 50ft of LMR400. Put it all together with the MFJ915 where it comes into your shack to keep RF out since you are using the braided coax as the counterpoise. You need a rig with an antenna tuner and it all works great across mutilple bands and the antenna will handle FULL POWER if you ever get a linear amp.
Total cost $80 for the MFJ1910, $90 for the 3132w balun, $30 for the MFJ915 isolator, about $55 for the LMR400 and about $25 for the 14ga wire and for about $280 you have a vertical that will handle 1500 watts full power and be able to raise and lower it quickly as needed and no worries about HOA's either since you just lower it during the day and raise it at night.
Best solution I found yet even though Im not HOA restricted. If you ever need to replace the wire its only $25 bucks at your local do it yourself hardware store too.
KD5SPX
Wayne in Texas.
