Better Antenna
Bonkk083
Union, SC
Radioshack 20-176 and Centerfire vhf/uhf which is the best between the two
About 25 years ago I tried a Centerfire UHF ground plane antenna on GMRS.
Was not impressed. Had a heck of a time tuning the thing to work well on GMRS, and I've tuned a lot of antennas.
You can do better, get some actual gain, and get more out of your radio.
Get something like a Larsen NMO-150/450/850 and a ground plane kit.
andy404ns
New Hampshire
My thoughts on the 20-176 are outlined in my thread here:
I love that antenna. I haven't used the Centerfire but it looks damn near the same. I imagine it's comparable. I'm not sure where you could find a 20-176 now so that might be your deciding factor.
Bonkk083
Union, SC
I have two of those I'm using one for the weather radio
Bonkk083
Union, SC
Will the Diamond d130j get farther away weak signals than the rs 20-176 at 159 mhz I have both antennas
Unlikely. The discone will have zero gain, just like the other two.
If you need more signal to your radio, you either need a higher gain antenna and/or coaxial cable with less loss. An amplifier would be another option.
If all you need is VHF, there are antennas that have gain that will easily outperform any of these three antennas. If you need more than VHF, the discone with low loss coax and maybe an amplifier if your local noise floor is low, might be a better choice.
Bonkk083
Union, SC
What amplifier would you use
I wouldn't. I'd go with a higher gain antenna. Choosing amplifiers take some skill and it will depend on what you are wanting it to do, and what sort of noise sources (cell towers, paging, NOAA, etc) are nearby. Amplifiers will boost everything in their passband and that can include things you don't want, like high power paging, etc. Those can overload the receiver and make things worse.
There are some on this site that have a lot of skill setting amps up, I'd defer to them.
Bonkk083
Union, SC
What antenna you recommend
