Beware of Ailunce HD2
Cashanova48
GMRS callsign WSAF780
I have also found out that the HT has horrible battery life. I keyed up on .5-Watt power on analogue just long enough to ident, I did this around seven times over the course of five minutes at most and drained 4% of the battery.
KI5YHO
Interesting… Although I don’t use it very often, my battery life hasn’t seemed to be that bad. Have you tried battery save functions in the main settings area in CPS?
Cashanova48
I have a little. I found out the other day if you turn Bluetooth off the battery life is increased dramatically.
doc62
Latest video on YouTube (this week) shows that even with updating the HD2 firmware to the latest version, the spurious emissions are still there despite Retevis saying that it fixed the problem. Doesn’t surprise me.
Sinister_Angel
Florida
I’m having issues connecting to some of my repeaters in my area as some of them go into 147mhz range which this radio does not transmit on for some dumb reason. I also noticed the TX restriction on frs/gmrs frequencies and this is a MAJOR bummer. This radio would be amazing if the menu and tx restrictions weren’t so bad. If there’s a modified firmware or something I missed lmk I would love to open this radio up.
Cashanova48
You should be able too change the band plan via doing a button combination while turning on the radio (I've long forgotten the combination). You can even create your own VHF and UHF band plans for the radio.
