BK KNG P800 NAS questions
policefreak
Berlin, NJ
I have 2 BK KNG P800s I'm using in Non-affiliate scan mode to scan some local 700/800mhz systems here in the NE US.
First off, is there a way to allow the unit to scan more than 16 channels at once?
Also, is there a way to program in a "Wildcard" to a given scanlist in order to test a new system coming online?
Thirdly (and unfortunately I may already know the answer) is there a way to program in a Motorola Smartzone system into a KNG-P800? And I don't mean to just scan the voice frequencies as conventional channels.
Thank you in advance, any help is appreciated.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Pretty sure it's no. no and no.
motorcoachdoug
Silver Spring, MD
If you want to listen to ALL the TG on one channel only enter a 0(zero) in the talk group setting. that will let the radio receive all the TG in the system. I learned that trick 4 yrs ago when I had my TP9400. As for monitoring more then 16 channels at once , nope and you can not mix conventional and trunked systems together to monitor as well.
policefreak
Berlin, NJ
So for anyone who is curious, yes, programming TGID 0 does work as a wildcard. Now I have to figure out if the programming will allow the radio to display a TGID in this mode, and if nuisance delete is possible in this mode.
gtaman
GALAXY 19 91.0° W
It will display the talk group. As long as you have the alt or primary line set to talk group.
I am not sure about nuisance delete
policefreak
Berlin, NJ
Thank you. I'll report back about nuisance delete. Of note, the system I listen to has a lot of encryption and i did not hear any scrambling in the 30 minutes or so I monitored this system in Wildcard mode.
gtaman
GALAXY 19 91.0° W
The radio mutes ENC without a key by default.
Sometimes though, you may see the Ø briefly and a quick garble.
