DSDPlus Blocking out the view of talkgroups
Remington12G
GØT AES?
There is a talk group on a system I monitor that constantly puts out Telementary and ties up my log, is there a way I can block this TG from my log and not see it so I can get back to monitoring.
u2brent
OAMPT
KRWDPAXKRS1
Lower the offensive TGID's priority & L/O if appropriate in the Groups File, And Increase the Threshold Level above that TGID's priority value.
Remington12G
GØT AES?
It shows normal in groups but has 0 priority. Priority override is normal but I have tried it as lockout and it still doesn't change. Still seeing the TG in the log
u2brent
OAMPT
KRWDPAXKRS1
Try a priority of 99, IDK Make sure the Monitoring Threshold is higher than 99 (found on the Control dropdown menu)
u2brent
OAMPT
KRWDPAXKRS1
Hmm, Truly sorry about that, I guess someone smarter than I will have to chip in here to help you.. I hear there's a few around if they choose to help.. (y)
u2brent
OAMPT
KRWDPAXKRS1
Had a thought, IDK if this would have any bearing on your issue, But maybe try setting Data Calls to L/O on the Control Menu if it isn't already set to that... Beyond the above already suggested I'm stumped.. :unsure:
Remington12G
GØT AES?
It was already locked out but I put normal and locked it out again, now I'm seeing more events on the log and the activity panel is showing it locked out and I can hear again finnaly. Thanks for your help
cg
Connecticut
Make the priority for the offending talkgroup so it is above the monitoring threshold and in the MISC tab, choose "Hide All BG Events and Traffic Below Mon Threshold"
chris
