APX Bluetooth Programming
ferryfan_ray
PNW
Hey! So today i purchased an APX4000, but... I don't have a programming cable, it has Bluetooth capabilities, and the Emergency button is set to BT On/Off. but there is not a menu option at this moment:( . Is there a way to program it via BT with just the Soft key and software?
cavmedic
Pottstown Pa
If my memory serves me, you create a personal area network with the BT on the programming machine , then you connect the radio to that network. It’s been about 4 years since I’ve done it but there may be other menus items that must be enabled on the radio to get more options first that I can not remember.
You may find it easier to just get a cable first for initial programming, and use BT later for quick touch ups.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Just turning the BT on and off doesn't give you the ability to make it initially visible and know if it's programmed to just LF MPP BT type only.
n3obl
ØAES-1056
PA
You usually need to do initial programming with cable as the Bluetooth is default to Motorola touch pairing only.
Cable can be had cheap on ebay.. either oem or bluemaxers49.
hakwye8518
Town of Islip, NY
As other have said initial programming must be done with a cable. Before you do your initial programming under Radio Wide scroll down to Bluetooth and change the pairing type to LFMPP & STANDARD and have BT as a menu item. After your initial programming pair the radio with your computers Bluetooth and make sure you change communication method to Bluetooth in apx cps and program away.
