kappajoe
going to try a re-write of the image and step through the setup again
Can 2 feeds run on the raspberry?
Hi folks..
I'm having a similar issue with the Raspberry Pi not transmitting anything unless I restart the darkice service after a reboot.
The darkice service does show as being started but on my USB soundcard, I can tell if it is actually working as the Mic port led flashes when it is working correctly.
I had a similar issue with kplex for sending AIS information to Marinetraffic using a Raspberry Pi. It had something to do with the network IP connection not being established before the kplex program ran.
Could this be a similar issue?
Going to try this with a completely new build as I used the image - which works perfectly when darkice is restarted.
Declan
sudo update-rc.d -f darkice1 remove
crontab -e
@reboot sleep 60 && /etc/init.d/darkice1 start
When adding a 2nd USB Sound Card to my Raspberry Pi do I need to edit the "alsamixer" command or does it use the same as the 1st Sound Card? When trying to access "alsamixer" for sound card 2 I get the Following Error:
pi@bcfypi1 ~ $ alsamixer
cannot load mixer controls: Invalid argument
Any Ideas? Im going to proceed to see what happens but any ideas would be helpful
But squelch is a bit... awful. I had it set to 82.3 earlier today, and it worked great. Now it's like it's disabled. I set it to 83, and I'm still getting static, but transmissions are also being cut off in the middle.
I've had my feed running on a pi 2 for a year or more and curious if using something like this would be better and could replace the usb sound card? I've always had a problem with my feeds audio being low, and I have the config volume up and my scanner volume all the way up.
https://shop.pimoroni.com/products/pi-dac
Also, what usb sound cards is everyone using? Please post a link and any challenges or issues if any, please.
Anyone know how to set a static IP with this image ?
