Broken Pro-93
Navycop
virginia beach, va
The keypad didn't work.. I took it apart and fixed the key pad.. When I reassemblied it I think I put a hairline crack in the ribbon that carries a signal to the LED display.. It used to say "Welcome to trunking" when turned on.. I know it is not the batteries. The LED will light up when the "light" button is pushed (this was one of the buttons that didn't work before).. I was wondering do I have to stick a pin in the side and "reboot" or is that just to clear the memory?
mancow
N.E. Kansas
You probably answered your own question.
If you cracked the ribbon the LCD display isn't getting a signal. The LED backlight is a different circuit so it's still working.
That's probably going to be a factory fix.
Navycop
virginia beach, va
mancow said:
If you cracked the ribbon the LCD display isn't getting a signal. The LED backlight is a different circuit so it's still working. That's probably going to be a factory fix.
I live in Virginia Beach, VA. How can I find a radio repair shop instead of sending it to RS?
Thanks..
