Bronco Antenna
CaptDan
Ocala, Florida
This is the antenna mount I anticipate going with.
Recommendations for antennas are welcome. I would consider A dual band GMRS/MURS antenna or a single band GMRS antenna. Price is always a consideration, but not the only consideration. Quality & Performance is as important, if not more important.
Thank you in advance for your insight.
tweiss3
Is it time for Coffee?
Ohio
For a mount like that you are going to need a half wave/colinear or similar, something that doesn't need the ground plane. Possible antennas include but are not limited to Laird B4505CNS, PCTEL MUF4505NGP
If it's for GMRS, go with a dedicated 1/2 wave UHF antenna.
I've used Larsen for years, both on my own vehicles as well as at work. You can't go wrong with them.
In the last 2 years or so, I've started using a lot of EM Wave antennas, and and pretty happy with them also.
EM Wave: EMFLX-M10003-GPI: Mobile, 2 dB Gain, Broadband UHF, Ground Plane Independent, 380-520 MHz, Poly Spring
Larsen:
The Antenna Farm is shut down right now, but you can still look at their pages. Search on the brand/model number and you can find other dealers. arcantenna.com tends to have good prices.
K6GBW
Montebello, CA
Yeah, the Bronco has the same issue as a Jeep Wrangler. You can go with a small antenna up front using a hood mount. The advantage to those is that you can see them when you're off roading and you'll know if it's going to hit something. The performance will be compromised but for short ranges it won't matter at all. For the location you pictured, the halfwave is the way to go. Don't try and do a dual band antenna on that carrier mount, it just won't work well. If you primarily use GMRS for off roading and caravaning then just go with a good halfwave.
