Baofeng BTech UV25X2 audio/squelch issue
KD4SHK
GA
I have a BTech UV25X2 that has worked quite well for about 2-3 years. Recently, the received audio has disappeared. When I power up, the "Start" tones sound normal, so I know the speaker is working, but I cannot receive any transmitted audio. I've transmitted from a nearby HT, I've tried adding or deleting PL tones, without success.
If I press the "MONI" button, to force open the squelch, I can hear any/all transmitted audio just fine, but as soon as I close the MONI button, the audio goes away. It acts as though the squelch setting might be set WAY too high. I've adjusted the squelch setting, both with Chirp and on the radio itself, with no change.
Has anyone else run across this issue? Thanks in advance.
nd5y
Wichita Falls, TX
Well it's probably corrupted firmware or part of the memory that CHIRP and manual programming doesn't have access to or change. You probably have an unrepairable chinese brick.
KD4SHK
GA
Yeah, probably. I know with my UV-5R, Chirp lets me edit the actual squelch setting value, but I cannot find a similar "feature" for the 25X2.
