Baofeng BTech UV25x2 Programming Issues
MedicMike153
Milford, CT
Hello all. I recently purchased a BTech UV25x2. I have programmed it with CHIRP, which I have used before on several different radios. I can't seem to get the UV25x2 to transmit. I went through and looked over all of the info I can and even compared it with my UV82C portable. I have also noticed that if you select off in Duplex, it defaults to split with an offset of 1666.66665. I cintacted BTech support and they asked me submit a ticket to CHIRP, which I did last night. Thanks for any help or ideas.
MedicMike153
Milford, CT
I was able to sort out the programming issue. I tried to upload a code plug from a different radio without downloading radio first. Still having the duplex glitch.
