Budget radio for mototrbo
eclipse3256
ocean county nj
Sorry if this sounds like a dumb question. Looking to buy a dmr radio non Motorola that supports connect plus and anything non conventional mototrbo systems. Any help would be appreciated. Looking for uhf
R8000
Low Battery
I am not sure what your intentions are, but it doesn't sound ethical. If you are a user of these systems, you need to contact the system administrator. Otherwise, it sounds like you are trying to bootleg on someone's system. Genwatch can make you have a bad day of that is the case.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Connect Plus is a Motorola proprietary system so you'll need a Motorola radio. You'll also need your serial number or ESN entered into the controllers database for it to follow the system.
Project25_MASTR
Millennial Graying OBT Guy
Texas
If you need to transmit on a Connect Plus system or a Capacity Plus system, you're best off finding a used XPR6550 or XPR7550.
