I'm have a really annoying problem with this (admitted by others) buggy Uniden USB driver with ProScan.
BUT, it's not just that software thou it seems to be worse with it. The other S/W is Arc XT Pro.
I usually have the radio on (996P2), then open the program. The only time it connects if the program was already running and closed. Then I re-open it later in the same Windows session (Win7 Pro).
So I tired turning the radio off, run the program, but no difference. Thou that might not be any solution since the O/S did see the device.
It's almost the same deal with the mystery other program supposedly using the driver (which there isn't any).
I go thru those troubleshooting notes on the connect page, but that doesn't usually work. One way or another I get things back, but there doesn't seem to be a pattern. I have had some success using the 'Auto detect' vs the 'Set' function, but not always.
It's the driver from Uniden, it's in DM ok as Com 3, thou a couple of times it got bumped to Com 5 (no idea why). Other than a mouse, keyboard & 2 printers (usually off) I have nothing on any USB port. Anyone that has had similar problem found a sure fire solution??
