Cables required to program freqs. into VX-6000l
Edarmstrong
Boston,MA
Hi Folks,
Trying to program frequencies into a NOS 2016 vx-6000l (37-50). Could someone please tell me all the correct cables I need to do this?
[I believe the software is CE49. Not sure if the FIF-12a is the only cable one or if the CT-105 is needed also????]
Thx you
Ted
radiotweester
Oregon
If you want to go cheap as you're using it for RX, and just for search for VX-6000 programming or as Carlos said the actual part of CT-105.
on Ebay. They're $20ish and USB.
Yes, CE-49 is the software you'll need. It is pretty easy to find online for free. There's also a program called SVC-49, but it's only is used for alignment.
