You probably did hear AM in that range.
The air units use some of the Wulfsberg electronics RT5000 wide band radio which is capable of AM, all modes of FM and P25 digital from 29.7 to 400 MHz and FM and P25 digital from 400 to 960 MHz.
The extended range AM comm band is 118 to 151.9875 MHz and when I was working on some of the transmitter designs for Wulfsbergs comm lines a few years back we would frequently get customer eval or loaner radios back from CDF in our engineering lab that had AM comm channels with alpha tags that were set to frequencies between 137 and 151.9875 MHz plus even some AM channels down in the 30 to 36 MHz range along with numerous ones in the 225 to 384 MHz band.
Customs and Border protection would also use AM throughout the entire operating range of the radio as did Air Force, Air national guard and some of the other govt agencies that use the RT5000 series radios.
Frequently I would hear Air force instructors out of Luke AFB flying over the Bagdad Arizona area operating around 151 to 152 MHz AM.
If they were working with federal firefighting agencies then it's very possible that they were operating AM where you heard them.
Mike
Interesting! I've never heard of the "extended range AM comm band" before (well, at least not going all the way up to 151.9875MHz as you stated, only up to 144MHz on occasion) but then I've never worked professionally on military or government communications equipment (with one vaguely indirect exception). One of my old college friends used to work for Global Wulfsberg in Prescott, AZ (back when they had a place in Prescott). I recall his telling me about the wide range multi-mode transceivers used by civilian and government helicopters involved in fire and law enforcement mutual aid operations. When I first read this thread my initial thought was that something like this was being used and that either it was pre-programmed incorrectly with the wrong mode for the air attack memory channels or that the operator accidentally dialed up the air attack channel frequency with the mode set to AM. However, Brandon's post made more sense to me and seemed more likely but now, given your info, I wonder. Maybe so...maybe so...
I do know that USAF and other military air assets use AM in the 136MHz to 144MHz range, though, as I understand it, less frequently now then in the past. I agree with tomasG, however, in that it would not be normal accepted practice on the CDF air attack 151MHz frequencies.
Out of curiosity, kma371, what radio are you using when you hear this traffic? Another possibility is some strong nearby AM traffic from either the 118MHz-136MHz or the 225MHz-400MHz band is creating a "false" signal in your radio on the air attack 151MHz (supposedly FM) frequency but proving that would take some knowledge of the receiving radio's frequency plan (RF-to-IF up/down conversion, etc.) which varies by manufacturer and model and establishing a credible mathematical link back to the actual "real" source frequency.
-Mike
