Calls Platform
Listens2240
Guelph Ontario
I noticed today when I went to listen to a feed on broadcastify calls platform I was not able to. It said you need to have a premium subscription.
Kingscup
It appears nodes require a subscription but the playlists do not require a premium subscription.
egftechman
Node feeds are only available to the node operator to monitor their stuff. You do not want to monitor node feeds, you will likely miss calls if there are multiple nodes monitoring a talkgroup and the deduping algorithm chooses the one to take for that talkgroup and rejects the others (won't even take the upload)...
I'm not sure why so many are not understanding the concept. Ideally we would have many nodes covering an area to reduce the number of missed calls by providing redundancy/resiliency, "horizontal" scaling, etc.. If you want to listen to Mayberry PD, listen to their talkgroup, not the nodes capturing it. If you want to listen to multiple talkgroups, either create a playlist of everything you want to listen to, or have multiple windows open.
Napalm
Calls provider
Lake Co, Ind
Public playlists do not need any kind of subscription. I've made two available for "my" listeners to my nodes.
