Calls system rename
scottb908
Terryville CT
I just submitted a request (which got approved) for Terryville / Plymouth town services. I am not sure if I mistype something or not, but could this system be renamed to reflect that its Terryville Fire/Plymouth EMS/Plymouth Public Works
Node 3254
scottb908
Terryville CT
I also couldnt get trunk recorder to connect so went with SDR Trunk, Not sure if that will need to be updated too
scottb908
Terryville CT
@blantonl Will do. Since Fire/EMS etc are different frequencies, should I submit 1 for each frequency or pump them in with "internal" talkgroups into 1 feed?
Since Ill be putting in new applications feel free to kill node 3254
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Do it the exact way you previously did it but choose the correct ingest software. Whatever your node is named makes no difference and doesn’t matter, but what software you are using is important when we provision the system.
Thanks,
