I'm having a problem "Saving" from the scanner to a folder.
I want to save to a folder then wipe it and restore with confidence before making changes.
When you read the scanner into Proscan and or Sentinel, it saves to your PC. If you search your PC for "f_list.cfg", it will come back to whatever folder you told Proscan to save to.
Sentinel saves to
C:\Users\Preferred Customer\Documents\Uniden\BCDx36HP On your pc it would be,
C:\Users\
Your User Name\Documents\Uniden\BCDx36HP
I want to backup my Scanner Freqs (files) to my computer so I can restore to original after reprogramming. I would like to save scanner data to my computer then as/when needed, pull that data from my computer to the scanner to restore it...
Restoring to original, or previous will undo any changes you have made to the scanner since you last wrote to it.
When I program my scanners, I write to the scanner using either Proscan or Sentinel. I then read the scanner into whichever I did not write from. So if I wrote from Proscan, I read into Sentinel so that way I have 2 copies in the event that one of the programs develops an issue. I also copy the contents of my Proscan save folder and the Sentinel folder into my Onedrive in the event of a PC failure.
Another thing you could do is if you have a spare micro sd card with a usb reader, you can always, after writing to the scanner, you can then also write to the second card.
It best to always read the scanner into the software before doing any editing so Sentinel/Proscan always has exactly what's in the scanner.
