Can you merge 2 IG radio licenses?
Robert831
Hello
I have 2 IG radio licenses both with the same area of operation and some frequency are the same but not all, but each one has its own commercial eligibility. I am seriously considering ending one of my business and just keeping one. Unfortunately the business I am ending has the better radio system of the two. Can I merge my second license into my first license?
Hello
Are they under the same FRN, or two different ones?
Robert831
Same FRN. The first system I had was or is just much better than the second system.
That might be a good question for the FCC.
Seems like two options:
Either file for a modification for the license you want to keep. This may require involving a frequency coordinator and cost money.
-or-
Modify the license and change the name. <— likely easier. Since it's the same FRN, it's probably simple. Or, you may contact the FCC and someone will say "don't worry about it". Companies change names all the time. If the contact info and location data is the same, I doubt the FCC is going to be upset.
I think you can do this via License Manager function on the FCC page. https://wireless2.fcc.gov/UlsEntry/licManager/login.jsp
AM909
Radio/computer geek
SoCal
To change names or contact info without re-coordinating/re-qualifying, I think you're asked to confirm that it does not represent something like a "change in control", and will probably point you to documentation where that is defined. I don't know if different corporations (legal entities) are considered the same for this purpose even if they are 100%-owned by the same person/entity (if that's what you're describing). Read what they point you to and you'll probably want to verify with a phone call. Seems like they'd be happy that you're returning some frequencies – I'd bet the majority of licensees don't bother, leaving lots of wasted licensed but unused spectrum out there. :|
