- Joined
- Jul 19, 2019
- Messages
- 489
Anyone have a working list of Careflite radio ID's? I think CF3 is 88117. Been getting into these ID's on several systems lately. Kinda fun to use them.
They also use RIDs in the 7XXXXXX values on the P25 systems on their P25 radio on the aircraft.
CareFlite Dispatch appears to be 88275, 88276.
CareFlite 6 appears to possibly be 88114 on the MHz system and 7095207 on the Fort Worth Regional Radio System.
Also have another RID for CareFlite 3 on MHZ of 88136.
CareFlite 5 is possibly 88028.
Just keep in mind the Number signifies the Base at which the helicopter is stationed when they receive a call. While most of the time the same helicopter is on station at that base, it is Not always the case. If a helicopter is down for maintenance, a different helicopter will fill in, and use the call sign for that base. The radio ID will be different. It might be better to attach the radio ID to the N Number of the aircraft.Careflite Air Dispatch 88275
Careflite Air Dispatch 88276
Careflite 1 Ft. Worth 88004
Careflite 2 Dallas 88114
Careflite 3 Granbury 88117
Careflite 3 Med Crew 88136
Careflite 4 McKinney 88273
Careflite 5 Gainesville 88028
Careflite 6 Whitney 88129
CF4 was the hardest to get but I just 'landed' it today.
That's what I was trying to get at in post #3. While the flight might be dispatched to "CareFlite 3", when I look at Flightradar24, the aircraft I see may be something other than N419CF. And often, if I did not hear the original dispatch, when I look at Flightradar24, the aircraft in use when it passes over my address is none of the 'assigned' tail numbers. (I'm southwest of Methodist Central in north Oak Cliff, so a lot of times I hear copters overhead, such as CareFlite, Dallas Air 1, or one of the PHI copters that are going to, or from, the Desoto Helipad.)Just keep in mind the Number signifies the Base at which the helicopter is stationed when they receive a call. While most of the time the same helicopter is on station at that base, it is Not always the case. If a helicopter is down for maintenance, a different helicopter will fill in, and use the call sign for that base. The radio ID will be different. It might be better to attach the radio ID to the N Number of the aircraft.
Megahertz Technology DMR
Megahertz Technology Trunking System, Dallas/Fort Worth, Multi-State
Megahertz Technology Trunking System Profilewww.radioreference.com
That may be a TGID for communications with local agencies either for scene response, or passing patient status to one of the hospitals. If that is what they are using it for, then at some point you might also hear them on GATRRS.I just heard a dispatcher on the LCRA P25 System. They are CAREFLITE 7 i don't have a talkgroup yet..
Careflite 1-6 work off the DFW Trunked Radio System since they are in that area. Careflite 7 is new out of Burnet/Llano Co and works off the LCRA P25 system on talkgroup 6558. Most of the time, they will call their dispatcher and have them "patch" in the hospital. Usually by phone. So they give their patient reports that way. I know there is a new Medivac system in Waco but I haven't seen any frequencies for them yet. Find out where they are based out of A hospital? they may be on that hospital's system.
The CareFlite 4 base at McKinney National Airport is dispatched on the Megahertz system. Dispatch channel is referred to as Tones and flight following is Scene 3.The Dallas System is the megahertz one linked, correct?
I'm trying to get the helis based in Mckinney.
Likewise, I have heard CareFlite talking to Medical City Plano MedCom on the Frisco P25 system several times with patient care reports as they were inbound to Medical City Plano.The CareFlite 4 base at McKinney National Airport is dispatched on the Megahertz system. Dispatch channel is referred to as Tones and flight following is Scene 3.
