CB Cable Connector End Kit
john-o
Springfield, MA
I'm looking for a kit that'll allow me to install the male end on a CB cable. What kit would you recommend and how difficult is it (kit) to use. Also, the end plug itself, are they compression types or some other type, and are these male ends sold separately? Are there videos that'll show how to use the kits on the web. I'm new to all this CB stuff, just learning.
krokus
Southeastern Michigan
Are you talking about the coax connector, for the antenna? If so, that is a PL-259, and there are plenty of options for installing new ones.
Sent via Tapatalk
IdleMonitor
The Ottawa Valley - Eastern Ontario
https://www.youtube.com/results?search_query=PL+259+Connector
john-o
Springfield, MA
I purchased a Solarcon A99 antenna for my Cobra 29 CB that I'm using for a base station. I then purchased about 100 feet of 95-14400 RG8X to go from my antenna to another shorter cable that goes through a wall in my den, then into the back of my CB. In the process of negotiating the wall next to the CB, the male connector of the shorter cable came off. So I'm going to follow one of those videos on youtube by going to Radio Shack and purchasing another male end, some solder, a soldering gun and attach a connector onto the bear end of the short cable coax.
Thank you for the assistance.
Great web site - I can see I'll be back a lot. Good subjects to learn by.
krokus
Go to a hardware store that sells cable by the foot, and buy a few feet of coax, and practice on that piece. That way you do not trash the coax you plan on using.
Sent via Tapatalk
Blackswan73
Central Indiana
If you are using solder connectors, which is the best kind, use a high heat gun, not a 35 watt pencil iron. I personally use a 250 watt gun. Also be sure to use rosin core solder, not acid core (plumbers solder). Be sure to have some way to hold the connector while you are soldering it. It will get hot!!!.
jaspence
Michigan
PL259
If you have not done a connector before, practice, as suggested is the first step. Be very careful stripping the insulation off the coax. If you even nick the shield braid, one of those tiny strands can come loose and short the connector and make your radio a brick. When you strip the center wire you also need to be careful as a nick there can lead to an open connection.
john-o
Springfield, MA
The more I read about this, the more inclined I am to contact a local guy who does a lot of CB and Ham radio stuff. He's a business that doesn't live that far from me, nice guy too. In fact, I bought a small Wilson magnet antenna for my vehicle from him and he was more than helpful.
Get forum. Learned a lot by "sandbagging" as I've heard others on the CB talk about operators that just listen in. Great hobby. I should enjoy it.
Thank you for your help.
jaspence
Michigan
PL 259
A wise choice. I have been building kits (Heath Kits and Knight Kits to start) for over 50 years. Even experienced builders make mistakes, and they can be costly.
nosig55
NEKS/NWMO & SWMO
RS?
Really? Going to Radio Shack ?, let us know how that worked out....
MONITORING247
here there and everywhere
pick up a ham book and it will give you drawings and illustrations on how to put on a cb connector or this might help https://www.youtube.com/watch?v=ABO45xFZCv8 remember to check your work with an ohm meter strands of ground can get stuck and cause a short as soon as connector is on do a check from center to tip you should hear no beep both on the connector beep if get a beep from the outside connector to the tip you have a short and the connector will have to be reinstalled and cleaned.
