Scanner Tales: More weird scanners
There have been some really weird scanners made over the years, I have written about some of them. Here are a couple more that I recall seeing here and there.
GE Searcher
This thing (well two things actually) was a neat idea but flawed in execution. There was a handheld version as well as a desktop/luggable one. Both used the same method of “programming”. Each of the four channels had individual tuning knobs so one could tune it to whatever frequency they wanted as long as it was on the VHF high-band. The smaller one used a set of 6 AA cells, the big guy used 6 D-Cells or AC house current. The big’un also had an AM/FM radio so it could provide tunes or the local news.
I remember seeing these at the local Radio Shack back in the mid and late 1970’s. I don’t think they were a catalog item however, but some stores sold stuff that wasn’t in the catalog. They were also sold in other stores, I think they had them at places like Montgomery Wards and Service Merchandise.
The handheld version was bulky, even by 1970’s standards. Tuning it was pretty difficult, you had to wait until the station you wanted to hear was transmitting and hope you found it before they finished talking. While that was the norm for any tunable receiver then, it was more difficult as the knobs and range of motion was very limited on this radio. Once you did find the right station the radio was pretty stable.
The bigger radio, like many other portable radios of the time, was designed to be used at home or outside. You could plug it in to a wall outlet or run off the D-Cell batteries. Battery life was pretty poor but the AM/FM audio was darned good. The scanner was the same as the handheld one but it had an meter that doubled as a relative frequency display and battery level. One would think it would have also been used for signal strength but one would be wrong.
I played with one or two of these back then in the stores and I had a friend who had one. They were too expensive and limited to high-band only (so no State Police or UHF police channels in my area).
Bearcat BC-E 8-track scanner
This was actually a pretty effective little device from the early 1980’s. It was a VHF high and low band 4-channel scanner that was built into an 8-track cartridge and was plugged into your 8-track player. It had a door on the bottom for crystals and the audio came out the stereo speakers. Power came from the 8-track player, I assume they had some sort of power provided to the tape head or something.
My Dad had one of these in his Buick. He was heavily into 8-tracks and stayed with them even long after the rest of the world switched to Cassettes and later CD’s. He already had a CB in the car (at the time everyone did) and did not want another antenna on the car. He got one of these at Wards and I got some crystals for the local channels for him. The darned thing worked great!
The reception was darned good considering there was no outside antenna capability. Somehow it was able to utilize the stereo for the antenna as well as power and audio delivery. It used the same 10.8 MHz. IF crystals as other Bearcat scanners of the era.
We had the local police, fire and Sheriff’s channels in that little radio and it got a lot of use. It disappeared eventually, I never figured out whatever happened to it.
Scanocular
This was quite possibly the weirdest radio I ever saw. I had seen pictures and heard stories about this but never saw one until I set up the Scanner Master Museum. Made by (or rather for) Memorex (the recording tape guys) I suspect the scanner part was supplied by Uniden or one of its suppliers.
This thing was a 100-channel scanner covering the VHF high, UHF and 800 bands as well as FM and TV audio. It was built upon a set of 8x25 binoculars. Intended for the race or airshow fan in particular, the idea was that you could watch the action and listen to the scanner at the same time.
I never really got a chance to use one of these but from what I have seen and heard neither the scanner nor the binoculars were very good. It did not have a speaker; you used earphones only. Probably a good thing as the sound levels would have made a speaker pretty much useless at racetracks and airshows anyway.
Regency MX7000
I have written about this before but it bears repeating here it was so weird. When it was introduced the ads showed a case the same as the then current Regency scanner and RH256 two-way radios with a wedged front panel. I thought this would be great, my first 800 MHz. scanner and I could slot it right in where the M100 was in my car with my UHF and VHF Regency mobiles. When I got it however I discovered that the MX7000 was markedly smaller than the other Regency radios and had no mounting holes. It didn’t even have a mounting bracket for the car.
Eventually I was able to source a compression bracket for it but it too was weird. I did try it out in the car but reverted to my trusty M100 as it had a faster scan rate and fit the aesthetic I had going at the time.
The MX7000 was possible the most sensitive scanner I ever had. It would pick up full-scale stuff on a whip antenna that barely ticked the squelch on another scanner on an outside antenna. It also had full coverage, including the cellular bands and was one of the first radios I used for Military Aviation. It had however very poor selectivity.
The biggest problem was the scan speed. You could measure it with a calendar if you were patient, it was that slow. The other issue was the power connector. While it came with an AC power cable, the connector was this weird 3-pin thing in a triangle layout. I ended up drilling a hole in the back of my radio and putting in a coaxial power plug.
Radio Shack PRO2026
This was the first scanner I ever bought that I truly and deeply hated. This thing was an abomination from the start. Built by Uniden for RadioShack, it took all the good Uniden features out and replaced them with all the bad Radio Shack ones. One of the big difference between Radio Shack scanners and those by Uniden/Bearcat and Regency was that one needed to press the “Program” button on RadioShack scanners to go into programming mode. On other scanners you could just type in the frequency and press Enter.
The PRO2026 was basically a neutered BC760XLT, same case style and shared innards. Instead of the easy programming of the BC760 and it’s kin one had to use the silly Program button on the 2026 in order to program it. They also had to add a couple additional buttons to the 2026 to handle the RadioShack programming methods, this made the action buttons under the display smaller and more difficult to operate.
Perhaps it was my aversion to the operation of the 2026 that clouded my opinion but I could have sworn it was far less sensitive and selective than the 760. I had both and always thought the 760 performed much better.
I never before nor since despised a scanner like I did the Pro2026. Perhaps it was unjustified but abhorrence rarely is.
trentbob
W3BUX- Bucks County, PA
Found this one in an Ebay auction. It's a Fox BMP 10/60. It does not have the door on top that you mentioned, but is 10 channels. No yellow panel on front either. Does this one have any similarities to the one you had?
Yes I just saw that one now and was going to post it, the logo is the same. There's a good chance that my cognitive deficits didn't remember the radio and this is it but I don't think so. This is direct entry on a keyboard and it's the same kind of keyboard that the pro 2004 GRE had. Regency also had similar keyboards. I just don't think this is the radio, I think the one I had was smaller but who knows, wait till you all start losing your mind, it's not fun.😆
kc2asb
NYC Area
My guess is that your memory is right on this one. The door on top / non keyboard programming is a very specific recollection. Who knows, someone here may remember the brand or even have one in their collection.
trentbob
Yes same with the row of red diodes scanning I do remember. Probably weren't that many of these radios around but it certainly was an oddball.
ratboy
Toledo,Ohio
One of my oddballs was a (I think) 700, maybe 750 channel Japanese made base mobile scanner, I thought it was a Yupiteru, but apparently not. It was about the size of a Uniden SDS200, maybe a little wider, and it had an LCD display with a green backlight. The numerals on the display were like about an inch and a half tall, which was nice to see in the dark with the dim backlight on. Sadly, it had really poor performance, and ran very hot, even on 12V. No PC programming, if it locked up, you had to do it all again. Very nice looking. I sold it off pretty quickly, as it was semi useless, except for cordless phones, it did them very well, but no better than my PRO-2004/2005's did. It did OK with a rubber duck stuck to the back of it with a 90 degree adaptor. Any real antenna brought pagers, FM BC, and even truckers on the Ohio Turnpike stopping scanning for a few seconds, blasting all kinds of horrible noises, and then it would take off again. A filter added to cut the under 30MHZ freqs helped a lot, but didn't cure it. Slow scan speed, like 30 a second. Good audio with the vents top and bottom.
I looked for it online, but I couldn't find a pic, it would help if I could remember the brand. I bought it used at a hamfest in the Chicago area about 1996/7? Grey cabinet, buttons on the right front panel, display at the top left. I just can't remember it, it was very rare apparently, and they didn't make many of them.
spongella
N2HUN, Western NJ
GE Searcher
Scanocular
Regency MX7000
Radio Shack PRO2026
I had the Memorex Scanocular, even wrote an article about it. Mario snags a Memorex TrackTec Scannocular!
kc2asb
NYC Area
From the physical description, maybe it was an AOR, like this AR-950? Though this radio is only 100 channels.
WatnNY
Living The Dream In Tennessee
The 2026 certainly was a abomination. The RS brain trust took a perfectly good 760 and turned it into an annoying POS. I still have a couple of them :(. Aside from the clumsy RS programming protocol, this radio had a volatile memory--it required a constant 12v source to keep the programmed channels intact.
This could be worked around fairly easily for a base install, but mobile installs required creative wiring. At least, back then, vehicle wiring was a lot simpler.
I had one of those! They were great for listening to baby monitors and cellphones "back in the day."
mikegilbert
MHz so good
Los Angeles
I'll add my single-DIN Kenwood RZ-1 "wideband receiver" to the mix. Would've killed to have this in my car back in the day.
  • 100 mermory channels
  • Alphatags
  • 500MHZ-905MHz continuous reception
  • AM / FM / NTSC
  • Stereo outputs and a video out for TV viewing!
They were popular in our live trucks as off-air receivers. That's where this one came from.
ratboy
Toledo,Ohio
No, not even close, the radio I had had a metal case, the digits were like over an inch tall, and it had a really potent green backlight when it was on high. The digits were on a slight angle, too. Almost the whole left side was the readout and icons. It was much nicer build quality than any AOR radio. I just can't remember the brand at all.
kc2asb
NYC Area
The construction sounds commercial grade. Maybe it was made for the Japanese market only? It had 700 or 750 channels? That already makes it unusual for the era, if you bought it used in 1996-7 and it was a few years old at that time. 400 channels was a lot in those days.
Yupiteru did have the display on the left side and green backlight. This one is the right era, introduced in 1992, but is only 200 channels and the digits are not over an inch tall.
It is a good mystery
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
  • Alphatags
  • AM / FM / NTSC
I always thought these were cool as heck. I seem to remember they were deaf as a stump though. Something like 5 μV on VHF?
dispatchgeek
My number was a slight bit off. Still terrible numbers. Sensitivity on the Kenwood RZ-1 (courtesy of rigpix.com)
FM >60 MHz: 3 uV (12 dB SINAD)
WFM 83 MHz: 1 uV (12 dB SINAD)
AM MW: <10 uV (10 dB S/N)
AM V/UHF: 5 uV (10 dB S/N)
kc2asb
NYC Area
A better contemporary option was the Yaesu FRG-9600 (from RigPix.com). Or, if you had deeper pockets, the Icom R7000 / 7100.
Sensitivity:AM-N: 1 uV (10 dB S+N/N)
AM-W: 1.5 uV (10 dB S+N/N)
FM-N: 0.5 uV (12 dB SINAD)
FM-W: 1 uV (12 dB SINAD)
ratboy
Toledo,Ohio
It's not it, but it's the closest I've seen. The display is too small and narrow, the buttons on it were rectangular not rounded. The angle of the digits is about right,but I would guess about half as big as on the mystery radio, and the backlight is really a potent green on bright. I wouldn't doubt that it was Japanese market only, I got it in Michigan, I'm pretty sure, and a lot of weird stuff came into the US and wound up on hamfest tables via Canada, like the Yupi scanners. I have a couple of weird Standard/Marantz Japan made aircraft scanners that are very rarely seen in the US. All the Standard stuff looks "Standard", so it's pretty easy to spot. Here is the Maycom 108, mine is a sad mustard yellow. If converted to receive all of VHF high, it's a decent radio to take to a race or airshow. No mil air, and truly awful speaker, but with an earphone, it's not that bad. I've seen it under several different names.
images
KE4ZNR
Radio Geek
images
Radio Shack used to have a version called the "HTX-200".
I still have one stored away somewhere....never did use it much.
ratboy
Toledo,Ohio
I forgot about that one. Mine had the "sticky" coating thing going that old radios seemed to get for some reason, I spent a lot of time and effort getting it off. I can't remember the name on the other one, slightly different, I haven't seen it since about 2017, when I moved. I'm 99.9% sure it's the same radio inside, but it had a non-sticky case made out of a different plastic, and seemed to have a better speaker in it. Oh well, I sure wish I could remember the 700/750 channel radio and find it. I guess I should have taken a pic just to remember it by.
ratboy
Toledo,Ohio
This is a poor drawing, but it has the general layout of the mystery scanner, the brand was across the top, just above the display. I don't remember if the channel number part was a seperate display or just part of the main one. I would guess the main freq display digits were about 1 inch high. Those big digits cranking away was what got me hooked into buying it.
Under the freq was a bunch of icons to show functions turned on and off. It was painted gray and seemed very solidly made, but it was a huge hassle to program due to GRE and Uniden having all the patents. Not a rocket scanning speed either, maybe 40 Ch/Sec.
ratboy
Toledo,Ohio
Just looked at info on the HX-200, and it isn't the same radio, it's a transceiver and the AR-108 and whatever the other one is, are receive only. But obviously, made on the same chassis.
