CDM 1550LS UHF Problem
lilrebo695
Hello out there I have a Problem that I thought I would get some feedback from people here before I take it to the radio shop and start throwing money at it. Here is the issue:
I am able to recieve transmissions without issue but I can not transmit out, The Tx light lights up but it's as if the mic is on mute or something as no one can here me or anything (static included) when the Tx button is pressed. It's a simple install with Power and ground wires run directly to the battery to avoid interference with the other equipment and a Simple Magnetic mount antennae, no other accsessories are installed.
Any help is greatly appreciated!
firefive76
Kansas
Confirm that you are sending out the correct frequency and pl/dpl tones. If thats all correct, you might have a bad mic or mic cord.
