CDM1250 Remote Head Cable Length
mpaine
Network Engineer
USA
Anybody ever experimented with the maximum distance a remote head can be from the transceiver on a remote CDM1250? Also, it’s just a standard RJ-45 style connected and UTP cable right?
I've run about 25 feet without issue. I don't know what the limit is, but I seem to recall someone doing close to 100.
The "Official" Motorola cable is 10 conductor flat cable (not twisted pair). It uses an RJ-50 connector on the end.
But the outer two pins are used for handset audio, and if you are not using the telephone style handset, a standard Ethernet 4 pair rj-45 cord will work just fine. I've done it before.
a417
Longest kit was the RKN4079 which was 20 ft (7m), and it was RJ-50 / 5 pair. [edit] mmckenna is right, it's 10 conductor flat, not twisted 5 pair.
How far are you trying to go?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
It is actually an RJ-50 10P10C connector. #9 and #10 are control lines for DTMF if you use the AARMN4026 microphone. If you do not need DTMF, you can use a regular CAT-5 cable in place of the Motorola cable. I’ve heard of runs of 100’ with no problems.
petnrdx
Hudson, FL
We ran some that were over 125 ft.
Equipment room to dispatch work stations for back up radios.
Worked fine, but I would not attempt to program over them.
