Channels
hiegtx
Dallas, TX
Proscan don’t put all channels in when program with it why?
What, specifically, are you trying to program (or import) that you think ProScan is missing some items?
System? (a link if possible)
buddrousa
Look at your Import settings if it says Control Channel only that is all that gets put in.
The Control channels tell the scanners where the voice Channel is and the scanner goes there.
Unless the Frequency is Encrypted and that is EXCLUDED by DEFAULT but can be changed.
Also Looking At Smith Co Tyler Site it is Simulcast 3 Sites in Tyler all using the same frequencies at the same time Unless you are using a SDS100 or SDS200 your milage my vary with any other scanner.
Texas Wide Area Radio Network (TxWARN) Site: Tyler Simulcast (radioreference.com)
Looking at Smith County and Tyler no Encryption is listed so that is a good thing.
Texas Wide Area Radio Network (TxWARN) Trunking System, Various, Texas (radioreference.com)
Goodluck buddrousa
headlinemen52
wills point
Goodluck buddrousa
thank you
wtp
Port Charlotte FL
LindaleSmith851.075851.4125851.825852.075852.4875852.975853.250c
860.4875c
WinonaSmith851.1375851.450851.6875851.950852.550852.9875c853.9875c
ArpSmith769.28125769.53125769.78125770.08125770.50625770.78125771.03125c
771.53125c
BullardSmith851.2625851.550851.975852.2625852.600853.050853.325c
855.4625c
Tyler SimulcastSmith851.050851.375851.575851.775852.0375852.450852.900
853.075853.100853.2125854.9875856.2125857.5875858.2125c
859.2125c
i get 5 sites in smith county and the tyler one is simulcast which usually causes problems.
