cheap rx amplifier for 800mhz
N8DAD
Prudenville, Michigan
Hello to all
I'm looking to find a cheap 800mhz amplifier to help get stronger signal , using quad rg6
Short run of coax now on rg6 quad..
Any help on a half way cheapish amp
73 Barry
dave3825
Suffolk County NY
What antenna are you using? I have a discone that does ok on 7/800 but the piece of coax I have that has 3 1/4 of center conductor only pulls in 7/800 better.
chief21
Summer - Western NC; Winter - Tampa Bay FL
Receive preamplifiers for the 700/800 band need to have a very low internal noise in order to do you any real good. A "cheap" model will likely be very noisy and might even cause problems with images or other RFI sources. Also, in general, receive preamps work best when installed at the antenna rather than at the radio.
Ubbe
Stockholm, Sweden
Those PGA103+ amplifiers are good at a low cost. Nooelec has one but there are many others.
You will need to attenuate the 20dB gain to be something like max 6dB at the scanner or it will overload.
It can overload even with attenuation if you are too close to strong transmitters and a weak signal can be the result of desense of the receiver in the scanner, so you might in fact need bandpass filters or notch filters and even have to attenuate the signal slightly without any kind of amplifier used. It all depends of your unique situation.
There's always a solution but can be difficult to know what route to go until you have tested and tried different ones. Generally reception will improve the smaller frequency band you allow a receiver to see, using bandpass filters. A variable RF attenuator are very helpful, start at 0dB attenuation and listen to a weak analog signal and add attenuation and see if reception improves, then the signal are already too strong and need to be filtered or attenuated.
/Ubbe
lkas
Cheektowaga NY
