why cant chester county be monitored with a bcd 396?
Septa3371CSX1 said:Will the fire repeaters still be in service after this switch (160.185, 159.600, 159.735) still be active?
policefreak said:When they switch over, will we finally be able to monitor the system?
chankel said:So are you saying that a P25 Multinet 3 system can't be monitored by APCO-25 capable scanners even if the frequencies are programmed as conventional channels? If so, please explain. I fully understand that it can't be tracked as other LTR systems are, but setting up the frequencies in conventional mode and locking out the home channel should still permit monitoring and decoding, correct?
Also, what range testing has ChesCo done to verify coverage? I haven't observed any P25 transmissions. Trying to implement the system without doing range and coverage testing would be a potential disaster.
chankel said:I suspected as much with regard to monitoring the P25 channels in "conventional" mode. It would seem that there is little benefit to keeping the LTR MultiNet system but going to P25 modulation. P25 comes with the set of signal reception problems unique to digital modulation, and an oddball system like LTRM seems to offer far fewer benefits than an ASTRO-type Motorola system that was built with digital and mixed mode operation in mind. Of course, any added level of complexity in any system increases the number of things that can go wrong.
ocguard said:how far along is this new system!?
DEPUTY11 said:Hmmmmmmm they are the same mobiles we have now? What's new about them and what are you talking on with the portables?
