Cimmeron decoder software
Kitn1mcc
Old Lyme ct
i picked up a Cimmeron ANI decoder the MDC1200 works fine. But i am looking for the software anyone have a copy seeing how they are out of business
WB5UOM
Its been awhile, but I am pretty sure you would use a terminal program to talk to it...Like putty, hyperterminal etc....
I had several of them out in the field back when.
WB5UOM
9600,N,8,1
on power up it will listen for 10 seconds at that setting..waiting for you to send:
$$CPlus
if it doesnt get it in that 10 seconds it reverts to the programmed settings.
This from some old notes
Kitn1mcc
Old Lyme ct
now here is the fun part getting the computer to talk to the unit. i am trying putty on my 7 computer and hyperterm on my xp system. should i have it set up as ansi or another way
AM909
Radio/computer geek
SoCal
Is it a real serial port and do you know it works? Unlike USB where the cables just plug and play, with RS-232, there are two "polarities" (DCE and DTE) for the ports and you have to get the cable wired correctly for the situation. Did you see @WB5UOM comment above about the settings and "password"? The emulation (ANSI, VT100, etc.) should probably not matter unless they were unusually creative in their UI.
Kitn1mcc
Old Lyme ct
yeah i know how those work. its just been way to long since i did the old way little rusty
