Clermont County TRS?
wolverine
Cincinnati, Ohio
Before the rebanding of the Clermont County TRS, my PSR-500 worked great, ever since the rebanding, as the scanner locks onto a talkgroup, i hear static that sounds like open squelch. When i open the squelch up a little so the noise stops, i start missing out on radio traffic as the scanner stops on a talkgroup but does not unmute voice. Does anyone know how i can fix this?
baj76
Uniden fanboy
I'm not an expert...but maybe you should try reprogramming your scanner
Only a suggestion..
wolverine
Cincinnati, Ohio
I did reprogram the scanner, i even double checked to make sure everything was right, and it hasn't worked right ever since, how many times do i need to reprogram it before it works right?
ibagli
Ohio
It sounds like the tables that are programmed aren't correct. Are you using the table shown here?
wolverine
Cincinnati, Ohio
I definitely haven't changed anything in regards to the tables, I've left them in there factory setting, this might alse explain why the Butler County, OH TRS is not receiving properly, It's a similar problem to the Clermont County, OH TRS which was also rebanded.
I know nothing about these tables, i will make the changes using the scanner's keypad. Do i just copy the changes from the site as listed below:
Thanks for the help
Table line 0
CH Lo: 440
CH hi: 559
Base Freq: 851.02500
Offset: 440
Step: 25.000
Table line 1
CH Lo: 0
CH hi: 719
Base Freq: 851.01250
Offset: 0
Step: 25.000
Update: These table setting's seem to work great so far, I've not went mobile yet.
jymypy123
Mt.orab ,Ohio
Clermont County Ohio upgraded radio system
is anyone know what Clermont county is upgrading there radio sytem to? and when this might take affect?
dalan57
Sabina, Ohio
pro 433
I have the same problem with my pro 433 tryin to get clermont programmed, have tried it twice and have the same problem the first post speaks of..any suggestions for a pro 433?
dalan57
Sabina, Ohio
Clermont county???
in the database on here it says clermont county is using the motorola type II system....i believe my radio is equipped for that I have a pro 433...but using the freq's given nothing but noise,,,anyone know whats up?
thanks
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Threads combined
All,
Not sure why, but a number of you elected to create multiple threads about the same thing. All have been combined into this thread.
In regard to your issues, check to see if the system is operating on new rebanded frequencies. If so, follow the instructions for your scanner to change the trunking tables to rebanded, or re-download the system using the software of your choice.
W8RMH
Feed Provider Since 2012
thanks
The PRO-433 does not support rebanding and the Clermont County system has rebanded.
FWIW I programed my BCD396XT with FreeScan from RR and it worked fine in July when I was in Clermont County. I actually received the system fine all the way to Leesburg.
radioscan
Radio Sensei
Southern Ohio
Clermont County uses digital voice, your Pro-433 would not be able to decode it anyway.
Sent from my GT-N8013 using Tapatalk 4
