matt04
Help. Has anyone successfully programmed a CLMRN site in a PSR600 radio? I have been trying to program Troop H site only and the radio does not receive.
I have done the same on a 396xt and it recieves fine. Troops still Ph1 for now.
I have seen some phase 2 usage on the troop H talk groups Over the last few days, not sure if it’s 100% of the time yet.
brndnstffrd
CT
I do. If you want to send me your programming file i can take a look and see if I find issues with it.
WoodburyMan
Southington, CT
Did anyone catch Statewide Common 3 on CLMRN last night?
30 minutes of recording from 10:41pm to 11:18pm
They were using Hartford sentences to test voice quality. Looping over and over.
Woman's Voice: The curtain rose and the show was on. (71-6) The young prince became heir to the throne. (71-7) He sent the boy on a short errand. (71-8)
Man's voice: Tear a thin sheet from the yellow pad. (64-1). A cruise in warm waters in a sleek yacht is fun. (64-2)
When I first heard it I was very confused until I google'd then words and found out what it was. Quality test for voice.
Same time ton Statewide Common 2 they were doing 5-4-3-2-1 1-2-3-4-5 tests as well. Talk of MCV. They were doing tests from Waterbury on the Mixmaster they stated.
WoodburyMan
Southington, CT
Also just noted that Troop I Simulcast (Site 29) now shows Sharon (Site 38) as a Neighbor. That happened recently. Can confirm it was not linked as of April, the last old backup copy I had.
What's funny is I can now get a partial signal from Woodbury for Site 38 Sharon. In DSDPlus it's bad where it's uncorrectable errors, but once in a while I'll get a single string or so of dad it recovers from CRC. This used to not be the case. I can also not get Troop B from where I am, which is odd. I think they might have expanded Site 38 or done something to it since it's now reaching Woodbury, and can link with Troop I Simulcast.
It's still only linked to Troop B as far as I can tell, and now I, although I'll retest some other sites later today.
WoodburyMan
Southington, CT
Site 38, previously thought to be Sharon / Sharon Hospital, has definitely had changes. I no longer thing it's Sharon and a 3rd ERV. The frequencies it uses are licensed statewide, and similar to the other inter-op 700mhz frequencies used but just a different control channel for the other ERV's.
I finagled my antennas and I was able to get a good DSDPlus read on it. To get it from my QTH it has to basically be anywhere from NNE to SSE of my location, approx 22 Degrees to 158 Degrees from Woodbury. There's almost no traffic on it too. And Troop I units are trying to Roam to it but being denied which makes me think it's around that area.
It is NO LONGER linked to just Troop B Simulcast and only linked to Troop H Simulcast (Site 28) and Troop I Simulcast (Site 29).
CC for possible "ERV3" is 774.51875 with ACC of 769.73125. NAC 3A9 Site 1.38 "38".
I will continue to monitor and see what happens. If anyone else can see if they can pick this site up we can narrow down it's location.
cg
Connecticut
Site 38 was a Standalone or fill-in site located at the Sharon FD. Not too long ago, that was changed to a full Troop B Simulcast Site rather than a Standalone. Likely set up as another fill in site rather than mobile. They can go anywhere as it would be a single rack of equipment in a shelter.
Here is an old site off Rt 63 that was not reused after the P25 change:
Old Troop B Motorola site
The antenna is on the top of the transmission tower.
chris
WoodburyMan
Southington, CT
chris
Makes perfect sense. When I was in Warren late last summer Troop L site still covered Warren. Make sense they would expand B and move the temp site somewhere. Judging by it's direction and area I'm thinking in I territory now, but near the H border. I don't have much traffic but this is what I got so far. No calls what so ever, just denies. Only accept was for some DEEP TG. Naugatuck site was the same when it was first set up as well.
Code:
2020/05/31  16:41:02  DSD+ 2.254 / Fast Lane Release
2020/05/31  16:41:02  [xxxxx  xx@xxx.com]
2020/05/31  16:41:02  P25 data loaded; 6 networks, 23 sites, 166 channels
2020/05/31  16:41:02  P25 Phase 1 and Phase 2 decoding enabled
2020/05/31  16:41:02  X2-TDMA decoding enabled
2020/05/31  16:41:02  TCP link established
2020/06/21  15:49:54  Freq=774.518750  NAC=3A8  Current network:  BEE00.3A9  CLMRN
2020/06/21  15:49:55  Freq=774.518750  NAC=3A8  Current site:  BEE00.3A9-1.38  Sharon
2020/06/21  15:49:59  Freq=774.518750  NAC=3A8  BEE00.3A9-1.38 neighbor:  Site BEE00.3A9-1.28; CC=1-2004  774.53125  Troop H Simulcast
2020/06/21  15:50:00  Freq=774.518750  NAC=3A8  BEE00.3A9-1.38 neighbor:  Site BEE00.3A9-1.29; CC=1-2012  774.58125  Troop I Simulcast
2020/06/21  15:50:14  Freq=774.518750  NAC=3A8  Rejection; Tgt=4552034    Reason=unknown[A5]
2020/06/21  15:51:55  Freq=774.518750  NAC=3A8  Registration; RID=1802704   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  16:02:15  Freq=774.518750  NAC=3A8  Registration; RID=1806555   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  16:06:17  Freq=774.518750  NAC=3A8  Registration; RID=1802418   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  16:06:58  Freq=774.518750  NAC=3A8  Registration; RID=1802650   TG=351 [[CSP Trp H Disp 1] Troop H Dispatch 1]    DENY
2020/06/21  16:09:36  Freq=774.518750  NAC=3A8  Registration; RID=45898   TG=5071 [[CTT Fastrak 1] Fastrak 1 Dispatch]    DENY
2020/06/21  16:23:06  Freq=774.518750  NAC=3A8  Registration; RID=1802077   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  16:23:42  Freq=774.518750  NAC=3A8  Message 190; Tgt=14680119   Src=4706960
2020/06/21  16:39:47  Freq=774.518750  NAC=3A8  Group call rejection; TG=1404 [[DEEP Spill] Spill]    RID=1961106    Reason=unknown[7B]
2020/06/21  16:39:54  Freq=774.518750  NAC=3A8  Group call rejection; TG=1404 [[DEEP Spill] Spill]    RID=1961106    Reason=unknown[7B]
2020/06/21  16:50:33  Freq=774.518750  NAC=3A8  Status 13056; Tgt=11116488   Src=5732720
2020/06/21  16:58:53  Freq=774.518750  NAC=3A8  Registration; RID=1562928   TG=48864    ACCEPT
2020/06/21  17:03:57  Freq=774.518750  NAC=3A8  Registration; RID=1561200   TG=48865    ACCEPT
2020/06/21  17:06:35  Freq=774.518750  NAC=3A8  Affiliation; RID=1563760   TG=285    ACCEPT
2020/06/21  17:08:57  Freq=774.518750  NAC=3A8  Registration; RID=45490    ACCEPT
2020/06/21  17:09:03  Freq=774.518750  NAC=3A8  Registration; RID=45490    ACCEPT
2020/06/21  17:09:07  Freq=774.518750  NAC=3A8  Registration; RID=45490    ACCEPT
2020/06/21  17:09:17  Freq=774.518750  NAC=3A8  Registration; RID=45490    ACCEPT
2020/06/21  17:09:19  Freq=774.518750  NAC=3A8  Registration; RID=1562224   TG=48864    ACCEPT
2020/06/21  17:18:36  Freq=774.518750  NAC=3A8  Registration; RID=1964105    ACCEPT
2020/06/21  17:18:36  Freq=774.518750  NAC=3A8  Affiliation; RID=1964105   TG=1404 [[DEEP Spill] Spill]    ACCEPT
2020/06/21  17:24:42  Freq=774.518750  NAC=3A8  Registration; RID=45152    ACCEPT
2020/06/21  17:24:45  Freq=774.518750  NAC=3A8  Affiliation; RID=45152     DENY
2020/06/21  17:28:26  Freq=774.518750  NAC=3A8  Status Query; Tgt=5755504   Src=1376553
2020/06/21  17:48:50  Freq=774.518750  NAC=3A8  Radio Monitor;  TX Mult=3  Tgt=4182640 Src=11075878
2020/06/21  18:09:04  Freq=774.518750  NAC=3A8  Affiliation Request; Tgt=11256108   Src=5558896
2020/06/21  18:23:18  Freq=774.518750  NAC=3A8  Registration; RID=8716698   TG=351 [[CSP Trp H Disp 1] Troop H Dispatch 1]    DENY
2020/06/21  18:24:37  Freq=774.518750  NAC=3A8  Registration; RID=1806555   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  18:24:53  Freq=774.518750  NAC=3A8  Registration; RID=1806550   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  18:25:45  Freq=774.518750  NAC=3A8  Registration; 040:16777215  ACCEPT
2020/06/21  18:40:56  Freq=774.518750  NAC=3A8  Registration; RID=891357    ACCEPT
2020/06/21  18:41:06  Freq=774.518750  NAC=3A8  Registration; RID=1806548   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  18:59:28  Freq=774.518750  NAC=3A8  Deregistration; RID=2085488
2020/06/21  19:00:09  Freq=774.518750  NAC=3A8  Message 51; Tgt=11075869   Src=1563826
2020/06/21  19:00:53  Freq=774.518750  NAC=3A8  Registration; RID=1561200   TG=27440    DENY
2020/06/21  19:26:20  Freq=774.518750  NAC=3A8  Message 31; Tgt=11075869   Src=1567856
2020/06/21  19:27:59  Freq=774.518750  NAC=3A8  Status Query; Tgt=2430340   Src=4219914
2020/06/21  19:29:15  Freq=774.518750  NAC=3A8  Registration; RID=1871030   TG=5631 [[Conn DOT D3] District 3]    DENY
2020/06/21  19:29:47  Freq=774.518750  NAC=3A8  Registration; RID=1964158    ACCEPT
2020/06/21  19:29:49  Freq=774.518750  NAC=3A8  Affiliation; RID=1964158     DENY
2020/06/21  19:30:41  Freq=774.518750  NAC=3A8  Registration; RID=45093   TG=5032 [[CTT NB Bus 2] New Britain Bus Dispatch 2]    DENY
2020/06/21  19:32:59  Freq=774.518750  NAC=3A8  Registration; 9EF:1485019  ACCEPT
2020/06/21  19:36:19  Freq=774.518750  NAC=3A8  Registration Req; Tgt=13644298   Src=2429089
2020/06/21  19:41:10  Freq=774.518750  NAC=3A8  Registration; RID=1804275    ACCEPT
2020/06/21  19:41:13  Freq=774.518750  NAC=3A8  Affiliation; RID=1804275     DENY
2020/06/21  19:57:43  Freq=774.518750  NAC=3A8  Registration; RID=45898   TG=5071 [[CTT Fastrak 1] Fastrak 1 Dispatch]    DENY
2020/06/21  20:01:28  Freq=774.518750  NAC=3A8  Registration; RID=1806569   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:02:20  Freq=774.518750  NAC=3A8  Registration; RID=1801372   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:08:39  Freq=774.518750  NAC=3A8  Registration; RID=1801513   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:09:51  Freq=774.518750  NAC=3A8  Registration; RID=1806550   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:10:39  Freq=774.518750  NAC=3A8  Radio Monitor;  TX Mult=2  Tgt=6623394 Src=13644322
2020/06/21  20:10:47  Freq=774.518750  NAC=3A8  Registration; RID=1804275   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:17:33  Freq=774.518750  NAC=3A8  Registration; RID=1806555   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:21:48  Freq=774.518750  NAC=3A8  Deregistration; RID=1823344
2020/06/21  20:26:52  Freq=774.518750  NAC=3A8  Affiliation; RID=1806168     DENY
2020/06/21  20:30:33  Freq=774.518750  NAC=3A8  Registration; RID=1806031    ACCEPT
2020/06/21  20:30:33  Freq=774.518750  NAC=3A8  Affiliation; RID=1806031     DENY
2020/06/21  20:32:35  Freq=774.518750  NAC=3A8  Registration; RID=1804275   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  20:33:48  Freq=774.518750  NAC=3A8  Registration; RID=45266    ACCEPT
2020/06/21  20:37:09  Freq=774.518750  NAC=3A8  Message 294; Tgt=1364996   Src=1365012
2020/06/21  20:49:56  Freq=774.518750  NAC=3A8  Registration; RID=1569392   TG=48864    ACCEPT
2020/06/21  21:06:00  Freq=774.518750  NAC=3A8  Registration; RID=1806550   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
2020/06/21  21:08:21  Freq=774.518750  NAC=3A8  Registration; RID=1806168   TG=401 [[CSP Trp I Disp 1] Troop I Dispatch 1]    DENY
WoodburyMan
Southington, CT
I just ran DSDPlus from Southington as well for Site 38's new location. The signal comes in so strong it's card to track with my directional antenna I use. It's just a hair shy of Troop I Simulcast's transmission, which is VERY strong. My guess is it's South of Southington along the 691 corridor. Cheshire, Prospect, Meriden area somewhere.
WoodburyMan
Southington, CT
Site 38 is not received at all from runway at Oxford Airport. If it was East of that location though, Naugatuck forest hills get in the way. I can't even get the Naugatuck site repeater from there. Just confirm's it's not South or West of Oxford. I was picking up 700 and 800mhz from Long Island.
So this all fits that its Prospect Cheshire Meriden area so far...
WoodburyMan
Southington, CT
Managed to actually get some activity on Site 38, Encrypted TG 2020, which is some encrypted CSP TG that's also TDMA / P25 PII.
It also seems to be accepting Troop L Dispatch Talk Group now.
87117
WoodburyMan
Southington, CT
Nothing new other than finding that CSP Training Car/Car and Dispatch, as well as DEEP West are allowed on this site. Lots of rejections from other TG's, aling with Channel ID's. Several days of monitoring, only these 3 frequencies seem to be in use with/without TDMA based on TG.
The more I think of it, I think this MAY be setup at the CSP Meriden Complex / Central District office. The signal from 3 locations I have tried seems to go with that. I'll try and get a better location fix then submit this as "Meriden" site. (Until they move it again, but given it was in Sharon for 1+ year worth labeling it for now)
87173
Cheeseburgers
Not sure if relevant as this is just anecdotal. Troop H from my office used to be full strength a few months ago... now I notice it drops in and out... what is full strength now from my office (Queen St. Southington) is Troop L Simulcast, full signal strength. Never used to be be like that. FWIW
darkness975
Latrodectus
They're probably reconfiguring the towers to focus on their respective zones.
