CM200 Squelch Adjust
70cutlass442
Is there a way to adjust to tighten up the squelch on a CM200 beyond the normal/local toggle? Not familiar enough with these to know if there is a tuner software such as the CDM/HT series.
cmdrwill
So Cali
Not sure on the CM300 but most mobiles of that era the 'squelch adjustment' is in the Alignment and Calibration AKA 'tuner software' in the CPS.
70cutlass442
I think you are correct. Do you know if global tuner for CDMs is the same or did the CM/PM series have their own tuner SW?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
First, open the CPS and read the codeplug.
Then, save a copy.
Click on VIEW and enable Expert Mode.
Go to the personality that needs a squelch adjustment. The fifth dropdown box from top is Squelch Threshold. Set as needed.
Save the new codeplug and write back to the radio.
70cutlass442
Then, save a copy.
I will try this, I need to really tighten this radio up, almost make it deaf so that a single high power transmitter several miles away will be heard... in CSQ.
