cm300/pm400 software
njffemt08
Was emtfirebug14
hey yall i found an old version of the software for the cm300. my question is if i purchase a subscription for motorola will i be able to do the new cm300d and does anyone know what other radios work with that software
clbsquared
Isle of Wight County
CM300D's require MotoTRBO CPS. It's not the same CPS as the CM300's. If you get an MOL account and purchase the MotoTRBO CPS, it will be the current version for all TRBO radios.
Sent from my HTC One A9 using Tapatalk
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Nope. The software for the CM300d (and other radios of the same family) is totally different from the now discontinued Commercial Series.
Search tags: The Commercial Series included:
Portables: CP150 CP200 CP200XLS PR400
Mobiles CM200 CM300 PM400
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with RVN4191 CPS.
The last version of the CPS released before the
product line was discontinued is R05.18.
If you need a blank codeplug, there is a folder
full of them, one for each possible model
number already on your hard drive. The folder is
in Program Files where your CPS is installed.
It is labelled SAMPLES.
njffemt08
Was emtfirebug14
clbsquared i do have a mol solutions account thats why i asked about purchasing from them. steve thankyou for that information i wasnt sure if there were more radios that where compatible with that software. also wondering if you guys no if the software for the mcs2000 and mp1500 radios is still available
