Coax Upgrade or LNA-5000 Preamp?
Aegir
Eugene, Oregon
I was just quoting the gain figure posted by the other op. I understand how it works, and don’t expect 6 dB from an LPA.
Ideally I would keep the discone, and add the LPA. Note- there would be a height difference as well as a location difference between the two antennas. LPA would be 10 ft higher than the discone. Also, the LPA would be clear from some large trees that block the discone from the north.
As far as the Gain on my Hustler G7 - mfr. specs. I doubt I have 3 dB gain on that antenna at 21 feet. But, it’s durable and so far a great antenna for what I use it for.
Thanks for all the info.
kb6hlm
Well you will love the LPA if you are after DX or just want to pick up those local weak signals the discone is ok for local repeaters but not worth much for DX
Like I said before you cant compare the discone to a beam in db gain as they are not same kind of antenna that would be like comparing a train to a airplane
You can expect the LPA to blow the discone away ! here is a tip I know this sounds strange but try pointing the LPA at a mountain instead of directly at the station if you can sometimes mountains make excellent reflectors
Here is one example : We have a 14,000 ft mountain here and if I point my 17 element 2 meter beam towards a repeater in AZ that's about 350 miles away from me I get nothing but when I point the beam almost the opposite way reflecting off the mountain it comes in fine I need to use 100 watts to hit it but it works fine :) I also need to do that sometimes to reach LA from here
Now try that with a discone LOL
BTW some bands like the 6 meters for example are horizontal mainly unless your working local repeaters you wont hear anything at all with the LPA unless its mounted horizontal
I remember years and years ago when I was a kid I had a UHF/VHF TV antenna mounted on two rotators that way I could turn the ANT to V or H depending on what I wanted to monitor it worked great on the scanner and man when I rotated to H it was night and day for somethings:) I remember one time I put it up on top of my dads tower and cranked it up 65ft and wow i was picking up TV from 100s of miles away ! that same antenna worked great for 6 meters as well but only in H and was useless in V however local stuff was usless in H
Anyway as you can see polarity is very important as well and that's my next project is to somehow hook up another rotator to that thing for right now its stuck in V for local stuff and some DX as well that comes in that way
Have fun with your new beam its a great antenna dont let the 6db fool ya ! :)
Ubbe
Stockholm, Sweden
Logperiodic antennas doesn't have pin point directivity, as it only uses 3 active elements, so if will receive more or less everything in front of it.
/Ubbe
kb6hlm
works great for me I just tried pointing it at the mountain and sure enough i was able to get a reflection just like my mono band beam
Yes I agree with the LPA having less directivity and gain then a mono band Yagi however with that being said I find it VERY DIRECTIVE ! unlike the pattern your showing however it dose work fine for the most part off the side
Example : if i move the ANT just one degree from that mountain all is lost
one other Example: where I live we have a aircraft approach frequency that comes in off the side of the beam however its down in the mud too far to be readable if i point the beam right at it I get a S-5 but if I turn the rotor just a bit its down in the noise again !
that chart is a computer model and dose not reflect real life experiences this is what I have been trying my best to explain to you all along don't pay to much attention to those egg head specifications :)
"It only takes minutes to create a chart like that but years to gain knowledge" I have over 40 of them :)
prcguy
Looks like you might be comparing HF horizontal Yagi's with an HF vertical. If so that has little to do with comparing a VHF/UHF vertical omni or Discone to a VHF/UHF Yagi or Log Periodic, which is what I believe is being discussed here. Comparing a VHF/UHF vertical omni or Discone to a VHF/UHF log or Yagi at the same height and same frequency range is apples to apples with the log or Yagi usually winning. A horizontal HF antenna, Yagi or otherwise is a completely different animal than an HF vertical with different forces acting on each in a different way.
Also, dBi is a world standard for antenna gain just like dBd. All commercial satellite uplink and downlink antennas are rated in dBi gain and not dBd.
You are joking right?
This is a tremendous amount of loss when you consider how much it takes to gain that much ! its night and day when it comes to weak signals at 3 db loss your signal is readable or not
Your comment about logperiodic antennas having 6db gain is irrelevant and not true at all to prove my point try using a discone the same height with the same coax and then point the logperiodic at the station transmitting and you will then see that the 6db your taking about has absolutely no relevance to anything
On your discone you may not even have a readable signal at all ! but with the beam you may have S-9 Plus !
you cant compare a Vertical to a beam the db gain on a Vertical has nothing to do with a db gain on a beam
I have worked all around the world with a three element beam that only had 3db gain and let me tell you something most of those signals did not even exsit on a Vertical and would have been impossible
Don't let those db gain specifications fool you its not fair to compare beam with a Vertical antenna of any sort just look at my example on my last post comparing a 6 db gain mono band Vertical to the logperiodic NOT EVEN CLOSE in fact it was a full 5 S units !!! so that would mean 30 db gain over a antenna that has 6db gain ??? see what i mean that makes no sense at all
Again dont compare antenna gain factors from verticals to yegis ! you can compare a vertical to a vertical or beam to beam but not to each other and even then the antenna manufacturers are taking about DBI (decibels relative to isotropic) this is foolish and its a way of making the antenna better then it is dont be fooled by this :)
kb6hlm
actually I'm not I was talking about the LPA and was just using some HF experiences sorry to get that confused with the subject
Well as far as UHF/VHF is concerned ya your right its not the same and VERTICAL / HORIZONTAL polarity is even more critical then HF !! its night and day
Anyway I don't think you quite understood what I was saying about db gain but that's ok :) everything I said in my post applies to HF/UHF/VHF or anything else for that mater
kb6hlm
3dB at receive are not much loss
I would like to apologize to you after reading my response to your first Quote I realize I went off subject and didn't make myself very clear sorry about that
After reading some of your posts you seem like a nice man and very intelligent that's why I was really shocked when you wrote
"3dB at receive are not much loss"
Looking back on it now it I really don't think that's what you meant and I would like to point out here for others to understand how much of a loss that really is!
Ill try to make it a simple as I can without a lot of nonsense :) lets say you have a water hose and the water is flowing out at 10gpm then you put a T on the end now you have 5gpm on each end right? same waterflow but only half now at each end that makes sense right? OK now for the hard part to understand but its really not that hard once you understand it
Now lets compare that with antennas lets say you have a LPA with 6db gain and you have at the radio a signal of S-5 and you put a splinter on the end of the coax for two radios well that's fine and it doesn't seem like a lot right ? well think about it you just lost half your signal strength remember 3db = half your power or in other words it would take twice the power to get 3dbs ! so now both radio are receiving at S-4.3 not S-5 any longer now that's a huge amount of signal loss ! it may not seem like much but lets say the station dropped into the noise level and is no longer there and you want it back? the station you was receiving before you put that splinter on is now GONE!! OK what can we do? add a preamp ?? nope wrong !!! remember a preamp doesn't actually amplify signals like the name implies (lets leave that for another thread) and there is no SIG to even work with anyway its gone into the noise and a preamp would just make matters worse ! so what do we do then ? #1 take off the splinter #2 raise the ANT #3 buy another $300.00 ANT for 3db ? really? wow
I vote for #1 take off the splinter :):):)
I know believe me I know its hard to understand how 3db is twice the power but it is and it takes a awful lot to get it ! lets say one yagi has 6db gain and you want 3db more you would need to add another ANT 6db+3db=9 and your still not happy ? well you would need to double that by adding 2 more antennas to get another 3db so now you got 4 antennas 6+3+3=12db so now you want another 3db do ya ?? well that's fine go ahead add 4 more for a total of 8 antennas 6+3+3+3=15 db now lets to the math cost=$300x8= $2400.00 bucks plus other parts for a 15db gain Antenna WOW !! that's nuts but people do it
Now that's for receiving so for transmitting you could double your power to get 3 db and then double it again for another 3db and so on and so on but think about this you still need to be able to copy the person right? and most antennas are cheaper then amplifiers however sometimes that's not a option
Anyway........ The next time you say "well its only 3db not a big deal" ( half your signal strength down the toilet!) :):):):)
73s
Gentleman
