I am currently using RG6 cable which is 30ft. I have some cable which is listed below (50ft) and need to know if I butt connected using BNC the two together if it will degrade incoming frequencies. Using a SDS200 scanner. I just want to get the antenna to the upper floor for better reception. I am using a wide band antenna. Thanks
The Commscope F6SSVV-E83032 is a 75 ohm coaxial cable with the following specifications:
- Brand: CommScope
- Manufacturer part number: F6SSVV-E83032
- Jacket color: Black
- Jacket material: Flame retardant PVC
- Center conductor material: Copper-clad steel
- Dielectric material: Foam polyethylene
- Nominal diameter over jacket: 6.02 mm (0.237 in)
- Center conductor gauge: 18 AWG
- Center conductor type: Solid
- Shield construction type: Dual shield
