COBRA 19 Plus. Schematic for early version?
wazz
Picked up a 19 plus as-is to play around with. Found on the bench it receives OK but the squelch is inop. Cannot see anything obvious. So I started searching net and found technical data and schematics for that model. However my radio differs from the info I found, quite a lot. This one is from March 88. This does not have the same board layout at all. Anyone enlighten me as to if this is an early version and where is data? Otherwise it is a pile of parts to me. Shame.
wazz
Turns out that I discovered that RV3 was the squealch range trim pot by tracing wires and PC board, and it was bad. So sqealch is fixed. Experience determination and luck comes into play but a proper schematic is alot better.
wazz
ALSO on CB tricks there is a 19+ service bulletin about a C54 in the synth. circuit that might kill alot of these radios. After awhile mine was slow to come on or acted dead. The SB refers to the little red tantalum C54 cap as needing to be replaced with a nonpolar equivalent. My radio was below the S/N range listed but I replaced that cap after freeze spray and heat testing it to prove it and now the radio plays fine. I have heard of some of these being DOA and poster could not figure it out.
