I'll try to refrain from that in the future. TNXWhy do you start a new thread for every question? Just continue in your previous threads.
Sounds to me like it’s trying to affiliate to a system.A bit of update, the radio transmits about 1 second, a digital signal looks C4FM (P25?)
Simplexed. 851.0625 I have seen before, likely a test frequency. I have an M-RK next channel down with test.
This is also a ruggedized radio so for est $40, I got a deal anyway you slice it.
I am working up a plan for what goes where, what I got so far is going through conventional, then cloning channels to trunking. 32 channels in scan list. you answered my question about talk groups, that is not so complex.Oh boy. Alright where to start
I've seen some cities pay people to sit there with a box of radios and a drill press, rendering every radio inoperable one by oneYep, sounds like it's been blanked or just never programmed. When I retired about 400 MTS-2000's at work, I put in codeplugs that had one RX only channel and all the buttons were programmed for "unassigned". It wood beep/boop if anything was done other than turning it on. Since the radios had data in them that would still work at our other sites, we didn't want to dump them and have them end up in the wrong hands. Not uncommon at all for people that have no idea what they are doing to buy used radios and just start using them on whatever channels are in them.
Well, there is no 'default', theres unprogrammed, or whatever someone left in there. When you get the right cable, you'll be able to read the radio.
Yea, I have it, used it, and even though it completed with success, much of the codeplug you still can't edit.There is an advanced system key removal tool out there on the web. It's not easy to find. It's probably easier to have a private conversation with someone in the know who does.
To be clear about it, no, I don't have it. I've never had a need for it.
That was my first thought given the dummy load, but a minimal nonconventional non trunking codeplug does the same. The battery icon shows and beeps. Hope the battery isn't failing, these ruggedized batteries are not cheap.Sounds to me like it’s trying to affiliate to a system.
What's your radio's flashcode? PM me if you don't want to post it here.
I'm vaguely remembering SOMETHING about the issue you describe, but not remembering the whole thing or the solution. Checking your flashcode may trigger the memory.
Has it been progammed previously with an Advanced System Key?
If ever there was a stupid idea Motorola came up with, it was the ASK. It has resulted in many radios going to surplus still programmed with
system data because the last technicians to touch the radio prior to retirement did not have the ASK or did not use it to deprogram the radio,
and then you have a radio that is permanently programmed unless you use the ASK removal tool.
Presence of the ASK makes the radio codeplug non-editable if you do not have a valid copy of the key itself.
From a security perspective, it makes sense to be able to lock the radio's personality so it can't be edited, but it should always be possible to completely DELETE systems data from the radio.
The codeplug has been blanked, former Brooklyn Park FD and out of MOTOs foundry.Take the antenna off, and wait until you get the cable so you can see what you have. Chances are the department had the radio shop default the radio somewhat. Once you got the software and cable from Motorola, you can read the radio and flashcode to see what is actually flashed to the radio.
They recycle the aluminum and metals on the PCB. ( a 48 Oz ball peen hammer works)I've seen some cities pay people to sit there with a box of radios and a drill press, rendering every radio inoperable one by one
