prcguy
Forgive me for chiming in again but the BC-610 transmitter is a WWII item (1942) and several radio generations before the R-390A which first appeared around 1955. The companion receiver to the BC-610 would usually be the BC-312 or the BC-342. The only time you would see a BC-610 paired with an R-390A would be by pure accident, or in a ham station.
There is no 24v power socket on the R-390A that I can find unless your describing the internal wiring harness that plugs into the power supply strip on the underside of the radio. This does not have any connections to the outside of the radio and is simply the main route between the power supply and all other modules. There are no external connections to the various B+ voltages either.
The rectifier tubes in the R-390A have 26v filaments, otherwise the 12v and 6v tubes are in groups wired in series so the filaments add up to 24v. Maybe there is a really special version of the R-390 that has these external filament and B+ connections but we can't find it yet. It would certainly be worth a lot of money if it turns up.
For the last 2 months I've been slowly bringing an R-390A back to life by replacing tubes, rebuilding filter caps and doing upgrades for AGC, SSB reception, extended audio response and general alignment. Maybe its a coincidence that I've been researching all the manuals and R-390 forums recently and that's where most of my limited knowledge of this radio stems from.
Working on this beautiful piece of mechanical and electrical art also brings back good memories of an R-390 and 390A I had in High School about almost 40yrs ago. I think the going rate was about $75 back then for a working unit.
prcguy
prcguy
"The R-390A Frequently Asked Questions Page is a link with information about the R390A, and clearly showing it a 115/230 VAC item."
Yes, but why then does the power socket have a 24VDC input to the heater strings? I'm still waiting to hear if there is a B+ connection on one of the rear panel strips but that should come in time. Oh and BTW I just remembered its mate was the BC610 transmitter.
