Well, FRS also requires a fixed antenna, is limited to 0.5 watt, and is FM which would make such a bizarre combination impractical and probably expensive...
Would a homebrew cross band repeater be considered "direct electrical control by wire" since it would be wired to the other radio?§95.419 (CB Rule 19) May I operate my CB station transmitter by remote control?
(a) You may not operate a CB station transmitter by radio remote control.
(b) You may operate a CB transmitter by wireline remote control if you obtain specific approval in writing from the FCC. To obtain FCC approval, you must show why you need to operate your station by wireline remote control. If you receive FCC approval, you must keep the approval as part of your station records. See CB Rule 27, §95.427.
(c) Remote control means operation of a CB transmitter from any place other than the location of the CB transmitter. Direct mechanical control or direct electrical control by wire from some point on the same premises, craft or vehicle as the CB transmitter is not considered remote control.
§95.412 (CB Rule 12) What communications may be transmitted?
(b) You may use your CB station to transmit a tone signal only when the signal is used to make contact or to continue communications. (Examples of circuits using these signals are tone operated squelch and selective calling circuits.) If the signal is an audible tone, it must last no longer than 15 seconds at one time. If the signal is a subaudible tone, it may be transmitted continuously only as long as you are talking.
. Frs radios are priced pretty reasonable, its worth a shot. :wink: 73, n9zasWell, FRS also requires a fixed antenna, is limited to 0.5 watt, and is FM which would make such a bizarre combination impractical and probably expensive...
A 27MHz AM 4 watt transceiver that will also do VHF FM in the FRS band at .5 watts and a fixed antenna? :roll:. Frs radios are priced pretty reasonable, its worth a shot. :wink: 73, n9zas
Nope, Frs and class D citizens band are two separate services, so not happening. You'd need one radio of each band.A 27MHz AM 4 watt transceiver that will also do VHF FM in the FRS band at .5 watts and a fixed antenna? :roll:
Well thank you for recapitulating what I've written previously Captain Obvious... :lol:Nope, Frs and class D citizens band are two separate services, so not happening. You'd need one radio of each band.. 73, n9zas
I read through the FCC rules and have a question about remote control.
Anyone have an opinion on this? I'd use a TK-880 for the UHF radio.
Get a yaesu 8900 and some export cbs that do fm and you will be all set !
. Why would a db admin give illegal advice? :roll: 73, n9zasGet a yaesu 8900 and some export cbs that do fm and you will be all set !
§95.655 Frequency capability.
(a) No transmitter will be certificated for use in the CB service if it is equipped with a frequency capability not listed in §95.625, and no transmitter will be certificated for use in the GMRS if it is equipped with a frequency capability not listed in §95.621, unless such transmitter is also certificated for use in another radio service for which the frequency is authorized and for which certification is also required. (Transmitters with frequency capability for the Amateur Radio Services and Military Affiliate Radio System will not be certificated.)
It seems a dual band CB radio is allowed if dual certified.
Guess that many of the newer CB radios are illegal that have the WX channels. Those are in another band near 2-meters. Thus, those CBs are multi-band radios.
No, they are fcc type accepted because they have a secondary receiver for nws channels. They cannot in no way transmit there. 73, n9zasGuess that many of the newer CB radios are illegal that have the WX channels. Those are in another band near 2-meters. Thus, those CBs are multi-band radios.
GRANT OF EQUIPMENT AUTHORIZATION
Certification
Issued Under the Authority of the
Federal Communications Commission
By:
Timco Engineering, Inc.
849 NW State Road 45
P.O. Box 370,
Newberry, FL 32669
Date of Grant: 01/28/2014
Application Dated: 01/28/2014
Uniden America Corporation
3001 Gateway Drive Suite 130
Irving, TX 75063
Attention: Al Baum
NOT TRANSFERABLE EQUIPMENT AUTHORIZATION is hereby issued to the named GRANTEE, and is VALID ONLY for the equipment identified hereon for use under the Commission's Rules and Regulations listed below.
FCC IDENTIFIER: AMWUT399
Name of Grantee: Uniden America Corporation
Equipment Class: Licensed Non-Broadcast Station Transmitter
Notes: CB Transceiver with Weather Alert
Grant Notes
FCC Rule Parts 95D
Frequency Range (MHZ) 26.965 - 27.405
Output Watts 4.0
Frequency Tolerance 0.005 %
Emission Designator 6K00A3E
Power listed is conducted. Operation as authorized by rule part only.
Not going to overthink this. MURS would be great for what you want, but the radios are scarce. Cobra 25's are good CB's, and most truck drivers have CB's in their trucks. Go with simple, quality, Cobra 25's and you are good. No, there are no "commercial grade" CB radios. Amazon.com: Cobra 25 LTD 40-Channel CB Radio: Car Electronics
