Looking for Rx/Tx antennas. I don't want to be pennie wise and dollar foolish on choosing a manufacture.This is an overly broad question. There are many different types of antennas within each band category. To get any sort of meaningful answer,, you're going to need to be more specific. And are you looking at an antenna for Tx/Rx or just Tx or just Rx?
What specific manufactures would you consider if you were going to install commercial grade antennas on a home / structure for each band segment.
- HF Bands
- VHF Bands
- UHF Bands
- Microwave Bands
- Satellite Bands
Mainly Long Distance at the start. (Tx/Rx)Depends on what you want. The type of HF antenna you need depends on what kind of communications you are doing? Long distance? NVIS? RX only?
Thanks. I've seen Laird mentioned on other posts, I'll keep this on the list.Lots of good commercial brands, although they can get -really- expensive, especially if you start looking at the higher end commercial repeater site type antennas. Very easy to spend $2K or more on a single antenna.
Laird makes some nice inexpensive commercial band antennas that are durable and affordable. Ran one on GMRS for many years.
Thanks for clarifying things!Looking for Rx/Tx antennas. I don't want to be pennie wise and dollar foolish on choosing a manufacture.
I understand that not every manufacture offers every type of antenna for every band segment. Don't want the 1st set of strong winds to destroy an antenna.
Decibel Products is a great company for commercial Vhf/Uhf.What specific manufactures would you consider if you were going to install commercial grade antennas on a home / structure for each band segment.
- HF Bands
- VHF Bands
- UHF Bands
- Microwave Bands
- Satellite Bands
The original company hasn't existed since 1992.Decibel Products is a great company for commercial Vhf/Uhf.
They are still around under the name DBSpectra and still make VHF/UHF antennas for repeater and trunking systems. I seriously doubt many, if any, hams would spend $2000 to $5000 on a VHF or UHF base antenna. They do not make dual-band antennas. They make two-port antennas vertically separated for repeaters and trunking systems with separate TX and RX antennas. For $8000, you can have one on your repeater systems.The original company hasn't existed since 1992.
Holy Cats! Nope, not in my budget lol!They are still around under the name DBSpectra and still make VHF/UHF antennas for repeater and trunking systems. I seriously doubt many, if any, hams would spend $2000 to $5000 on a VHF or UHF base antenna. They do not make dual-band antennas. They make two-port antennas vertically separated for repeaters and trunking systems with separate TX and RX antennas. For $8000, you can have one on your repeater systems.
Hmm... I'll have to check with management of my High Rise apt. building lol.OK for HF In would use a 3-30 MHz HY-GAIN model 2012AA Conical Monopole. It is a discone antenna design with very low takeoff angles with 4 dB of gain. SWR is no greater than 2:1 across the operating band of 3 to 30 MHz and capable of 50 KW PEP.
It’s not a discone, it’s a conical monopole just as it says. A discone is a completely different type of antenna.OK for HF In would use a 3-30 MHz HY-GAIN model 2012AA Conical Monopole. It is a discone antenna design with very low takeoff angles with 4 dB of gain. SWR is no greater than 2:1 across the operating band of 3 to 30 MHz and capable of 50 KW PEP.
I’m using a DB Products two port split 8-bay dipole array at my house for two separate repeater systems. What’s the big deal?They are still around under the name DBSpectra and still make VHF/UHF antennas for repeater and trunking systems. I seriously doubt many, if any, hams would spend $2000 to $5000 on a VHF or UHF base antenna. They do not make dual-band antennas. They make two-port antennas vertically separated for repeaters and trunking systems with separate TX and RX antennas. For $8000, you can have one on your repeater systems.
I am not really sure at this point. If I mount on the home, then I would be much more limited to the size of a boom that could be used, as I would be more limited to height of the antenna.How much room do you have? HF antennas that cover all the HF ham bands can be rather large.
That's like comparing General Sherman's March Into Atlanta to a Sunday afternoon family BBQ.This is an overly broad question.
