Connect DP4600 Series radio to PMR
sammyg512
I've been scratching my head recently, i've got a load of DP4400 and DP4600 radios that i use for events, but one venue uses Motorola Talkabout T92 radios, and wondering if there is a way i can change the codeplug to connect with the T92 radios too.
alcahuete
Antelope Acres, California
Yes. Just program them all for the same frequencies.
Here is what I'm showing for the channels from the T92 manual:
1 446.00625​
2 446.01875​
3 446.03125​
4 446.04375​
5 446.05625​
6 446.06875​
7 446.08125​
8 446.09375​
9 446.10625​
10 446.11875​
11 446.13125​
12 446.14375​
13 446.15625​
14 446.16875​
15 446.18125​
16 446.19375​
sammyg512
1 446.00625​
2 446.01875​
3 446.03125​
4 446.04375​
5 446.05625​
6 446.06875​
7 446.08125​
8 446.09375​
9 446.10625​
10 446.11875​
11 446.13125​
12 446.14375​
13 446.15625​
14 446.16875​
15 446.18125​
16 446.19375​
Heya,
I've tried adding those frequencies, and can see the radio is picking up a signal from the T92, however I'm not getting any sound, and unable to send a message to the T92.
alcahuete
It sounds like there is a tone involved somewhere. Motorola calls them Sub-Codes on that radio. They are CTCSS and DCS tones. You either need to turn them completely off, or match them between the two radios.
sammyg512
I've had a little look, and found out i was being a bit silly. The T92 radios are analog whereas i was trying to use my DP4600's in digital mode. Also, had to look at the Tone Frequencies, and found this which seemed to work when added to the Squelch Settings.
