County CommGP-5/SSB
ratboy
Toledo,Ohio
Ok, I've spent about 2 hours listening to the GP5/SSB in a good RFI free area, and here is what I've found.
I went to my usual train watching location in Holland, Oh, and Norfolk Southern has provided a nice chain link fence for me to clip the wire antenna to. I heard a LOT of stuff there, 20 Meters was busy, and I heard a lot of contest "junk" going on. Incredibly boring, but a lot of signals to listen to. I heard Radio Havana on a couple of frequencies, and they were very loud. A lot of the usual preachers asking for money, a numbers station in Spanish, and a couple of VOLMET stations in SSB too. SSB is clear, but there is some pumping due to the AGC. Again, since the AGC is not adjustable, this is as expected. I've never seen a radio without adjustable AGC that doesn't do it. The muting when tuning is odd, to put it mildly, there is a chuff/crunch noise with each step. If there is a way ( a mod) to defeat it, I would love to give it a shot. So far, this is my biggest annoyance with the GP5/SSB. At home before bed, I tried using just the built in whip on SW without much success. I heard Radio Havana again, a VOLMET station, and some others. I had the wire antenna clipped to the top of the drapes, with about 1/3 of the wire lying on top of the drapery rod, and then over to a lampshade. I used a plastic clothespin to hold the wire to the lampshade to keep it from falling off the lampshade when I took the wire antenna off, as the height of the wire helps reception, a lot. When I connected the wire antenna, it helped tremendously, and I got similar results to what I got at the tracks earlier.
1. Without the wire antenna, you won't hear much SW at all unless the conditions are fantastic, or the signals are very strong. No shock here. I didn't expect anything else.
2. You have to tune very slowly, or, due to the muting between tuning steps, you will miss or overshoot signals. In AM 1KHZ slow 5KHZ fast tuning steps, I frequently would overshoot signals twice, once in both directions as the variable step kicked in and instead of going up 1KHZ, it would go up 5KHZ instead, and do the same thing going down. Maybe it's just some getting used to it, but I kept doing it.
3. The form factor is pretty much perfect for one handed operation, in the right hand. The thumb is perfectly placed to use the tuning knob. The unit is so light, fatigue is not a factor.
My questions are how long the tuning knob will hold up as it's used a LOT. The volume control appears to be the standard one used forever, and they hold up well over time, but I don't know if the tuning knob will. Time will tell. As cheap as it is, I wonder what kind of lifespan it will have. My Sony ICF-2002 lasted a long time, but I paid about $120 bucks for it, I think, so it should have lasted longer. All in all though, this thing is a lot of fun in a tiny package, with surprisingly big audio.
ratboy
Toledo,Ohio
How can you go wrong with this thing for $90 including shipping? If you take the battery compartment out of it, the whole thing is about the size of an old crystal radio I had (And was caught listening to) in Jr. High about 45 years ago. I was looking in my "junk drawer" and found the little AM/FM receiver I used to take to the drag races years ago, with the earphones I made so I could listen to the PA system FM broadcast in one ear, and the scanner in the other. It still works, and the GP5/SSB kills it in every way, except in ruggedness, it's built like a tank, and the GP5/SSB seems a bit delicate. The labels are all worn off of it now, I can't remember what brand it was. I bought it in Columbus at Meijers for $5-6 after forgetting to bring my previous one. I sure got my money's worth out of it.
The SWLing Post review is good, I can't disagree with a single thing in it. The audio samples show it's a decent receiver. If the AGC would be slowed a little in SSB modes, it would be even better.
racin06
Westfield, Indiana
I've had my GP-5/SSB or 3 days now and I really like this little radio. Thus far I've monitored the USAF HFGCS, MWARA (Atlantic) and some HAM traffic using the provided wire antenna and the GP-5/SSB does a good job for a $90 radio. Of course, the GP-5/SSB won't compete on a level with a $500+ HF receiver; however, for a small SSB capable radio with ultra-portability, it's worth the $90.
Boombox
Does this radio you're using have a local / DX switch? It might tone down the reaction of the AGC to SSB signals, and clear up the SSB.
k9rzz
Milwaukee, WI
I'm sorry, but I'm just too old skool to enjoy a radio like that. Mine has to have knobs I can grab, switches that go 'click!', It gets warm over time, and if I drop it on my foot I say *OW!*
ratboy
Toledo,Ohio
I like and have one of those too, but I can take this with me and run it forever on 12V, something those room heaters just can't do..
ratboy
Toledo,Ohio
Nice job! I'm thinking about making an outside antenna and bringing it into where I normally listen to it. My computer/radio room seems to have some things that cause a lot of interference on the GPS/SSB, so it's useless on SW for the most part..
When anyone here has to/wants to take it apart, I would like to see inside it, just curious about what it looks like inside. It's one of my "things", looking inside to see what the PC boards look like in radios, etc.
jtcase
Park Ridge, IL
GP-5/SSB Si Chip Si 4735
I have both the Tecsun PL-360 and the newer Countycomm GP5/SSB. It seems to me the audio is clearer on the GP-5/SSB and it also is the more sensitive of the 2 receivers.
It has been published that the Tecsun PL-360 uses the Si 4734 chip, but I could not find out what the GP-5/SSB used. So, I opened both radios and took off the RF shields and had a good look. The Tecsun PL-360 definitely has the Si 4734 chip in it, while the Countycomm GP-5/SSB has the newer Si 4735 ship. Interestingly enough, I recently opened up a Tecsun PL-880 that I got for Xmas to see what was under the hood, and it is also the Si 4735. So, both the Countycomm GP-5/SSB and the Tecsun PL-880 have the same Si chip.
I posted photos of the Si chips in the PL-360 and the Countycomm GP-5/SSB in the photos section of the Ultralight DX Yahoo group
ratboy
Toledo,Ohio
Thanks for posting those pics! The GP5SSB looks about like I thought it would, except for the Si 4735 chip. I wonder if all the PL-880's hidden features can somehow be turned on in the GP5SSB? Could be interesting to see what can be done with it..
majoco
Stirrer
New Zealand
I bought the Tecsun PL-360, seems to work very well although the plug-in LW/BC antenna doesn't make much difference to the signal strength.
Question - the Chinglish handbook in the "Manual Tuning" section refers to a fast/slow tuning step but doesn't tell me how to get it. Anyone have a clue? I've pushed all the buttons with short and long pushes but none seem to have the desired effect. Tuning through the SW BC bands in 1kHz increments loses it's appeal after a while!
majoco
Stirrer
New Zealand
Ok - I've answered my own question, thanks to Google and N9EWO's review - the tuning knob is speed sensitive - turn it slowly one click at a time and it increments in 1kHz steps on SW, run your thumb over the knob at it ramps up to 5kHz. I s'pose it works, but it's not as convenient as a pair of "up/down fast" buttons.
majoco
Stirrer
New Zealand
The little caps on the end of the 'booster' can be taken off with a half-turn and reveal just a bit of ferrite rod. There's about 0.6ohms across the plug contacts so there's not a lot of wire in there.
I connected my tuned ferrite loop that I use for my lounge stereo into the socket and WOW - really brings in the distant stuff. I'll have to make a tidier ferrite tuner/antenna now - a big loop with a coupling winding would be even better.
