CPS help
Jasonk1
I am new to programming. I have a GMRS channel, and when I go to "Advanced," in CPS, I get all these settings such as "Compression type," "Expansion type," and
"Emphasis selection." What do all these settings mean?
Right click on anything you want to know and select What's This? and select See More Information, this brings up the CPS Help Files
K2NEC
5F6
For best results, use Disabled. I got a 750 a while back and it always sounded like it was in the dumps. Turns out my compression type was set to full compression. Not sure what the purpose is for it but it's horrible in my books.
Jasonk1
Thank you for your reply. Should they all be disabled or just the compression type?
Ant9270
The Green Weenie
Disable Audio Processing Filter as well. Awful setting.
ElevatorsAndRadios
yarewesog
SoCal
I believe it's supposed to improve audio quality when operating in narrowband. It should also be noted that this feature is supposed to be enabled on all of the radios in the fleet when in use. Since your audio was compressed but no radios were expanding it, that's probably why the audio sucked.
K2NEC
5F6
Sounds about right. Our town uses 7550e's and here I am with my cr*ppy HT750 :ROFLMAO:
Those settings being enabled works well if you are using all Motorola radios and they are set up the same way.
Most of the time. Emphasis/De-emphasis can suck.
For GMRS use, shut them all off.
Jasonk1
Thank you.
Bucks County PA
Speaking of the help files, does anyone have a copy in pdf form of them? No matter what I do on my Win 10 machine, the older help files won't open. I tried converting them to pdf but nothing worked..
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
It’s not a CPS problem or even a Motorola problem. Newer versions of Windows no longer contain the program that finds snd displays the help files.
I can’t find the link right now, but there is a downloadable fix on the Windows website
n1das
Nashua, NH
These are Motorola's X-Pand audio companding features. Motorola claims it improves the SNR and audio sounds "clearer", particularly when in narrowband mode. It all depends on how "clearer" is defined.
When full compression is enabled, full expansion is also enabled. It's an all or nothing type deal, sort of like using Dolby Noise Reduction on audio tape recordings. Analog cell phones had companded audio. The feature does work as advertised but all radios talking to each other need to be using it too in order for radios to sound right. When listening to compressed audio on a radio that doesn't compand the audio, the received audio from the companded radio sounds loud and punchy. The problem is the other way around where audio from a non-companded radio is heard on a companded radio. The expander expands audio that wasn't compressed originally and totally blows it apart and sounds like (expletive). I don't mind the full compression but wish Motorola would give the option to reduce the expansion ratio.
With compression disabled, I recall the choices for receive are Disabled or Low Level Expansion (LLE), with LLE being the default. I found this to be OK but makes the radio sound slightly "fuzzy" and slightly processed. The help file in the 750/1250 recommends this setting for best compatibility with radios that don't have X-Pand. Compression during transmit is disabled and only a small amount of expansion is used on receive. Disabling LLE also works fine too.
Motorola's cheap business radios and the Talkabout FRS bubble packs have X-Pand enabled all the time and there's no option to disable it. The business radios with wide/narrow bandwidth setting on some channels force X-Pand on when in narrow mode. The Motorola Talkabout FRS bubble packs could be greatly improved if there was an option to disable X-Pand on the whole radio or per channel. Motorola's higher end radios have the option to enable/disable X-Pand like in the 750 and 1250 but the cheap radios force X-Pand to be enabled all the time.
I've played around with these features but eventually end up disabling them.
K2NEC
5F6
Wow thanks for the whole explanation I didn't know any of that.
