CPS Programming
bezking
On the Road
Hi - I have a /\/\oto PR400 UHF Radio rated to handle between 465-495 mhz. Will the CPS allow me to program down to GMRS 462.55, and use seperate PLs for TX and RX ? Also does this do MDC1200 encode and ID display?
Thanks.
NY
no, if your radio is only 465-495 you cant go down to 462.55
Frs/gmrs doesnt do MDC1200 I dont think
Astro25
Chicagoland
I havent hacked any PR400's yet, but it's probably an .mdf hack or a hex hack of the actual CPS. From what I'm told, actual bandsplit limits/info are saved in the radio's firmware itself, and not on the computer.
bezking
On the Road
Hmmm, I thought that the CPS, if you did something weird, like hold down shift while entering freqs, would allow you to program any freq and force it?
Astro25
Chicagoland
No, you're thinking of RSS. The only CPS that does this is the 1225 series and mebey a couple others - but professional line CPS shift-key trick won't work (at least without any modifications to the .mdf file)
P1225
That never worked for me on a P1225. It's never worked for me on any window based Moto software. Like you said, just the DOS stuff.
Astro25
Chicagoland
What version were you using on your P1225? I've heard rumors that 4.0 will not allow that to happen, but some people have confirmed that it will allow out-of-band.
7586
NY
:() .........................:) For real???? I didnt know that.
