ct250 programming
Ramchops
I am trying to program ct250s and when I try to read radio I get this message: 80040154 couldn't create instance on device after getting UUID.
any ideas on the issues?
KG4INW
Midlothian, VA
Which CPS are you using and what is your cable setup? Have you successfully programmed one before?
Ramchops
HVN6053E is the cps Believe its R02.02. I have usb prolific cable which I have used successfully to program multiple cp200s and pr400s using RVN4191 cps.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
HVN6053 is the correct CPS for the CT250 radios.
According to all of my documentation, the programming cable for the Commercial Series portables (CP150, CP200, CP200XLS) is the same as used for the CT250 & CT450.
I am not well versed in the revision levels of this software, but is it possible that the radio was programmed with a newer version than you have there?
Ramchops
Near as i can tell, this is the latest software version. Any other ideas?
cabletech
Puget Sound
What cable are you using? Did you load the correct drivers? Have you checked to be sure your using the correct comport?
Were did you get the software? If you did a download from some xbvvmb,site, it maybe corrept.
If it is on disk, try unstalling and reinstalling.
Motorola did not publish a version past 2.02.
SteveC0625
Just a thought...
Do you know if this CPS platform sensitive? We know that Win 8 and Win 7/64 can be problematic for some CPS's. Others don't want to run on anything newer than XP. Etc., etc., etc.
For the OP, what are you using?
Ramchops
Its a disk and i reinstalled several times. Its a prolific serial usb cable and drivers should be good. i can program with the RVN4191 cps just fine. comport is correct,
Ramchops
Ok Steve, you may be on to something there... im using Vista,,, its the oldest os i got.
kharris8438
Davisville, WV
CT-250 Corrupt CPS issue
I recently acquired 3 CT-250 UHF 4 channel radios from my local hospital maintenance dept. and tried to program the radios with the latest version I had which I believe was the first or second version they came out with a decade ago. Does anyone have any ideas or how to reacquire the RSS since Mother M discontinued the radio and cancelled the software for purchase?? Any help would be appreciated or I will be giving the batteries and chargers to my Mutual Aid Dept. and then give these radios a good burial with my .45 ACP!!
