CTCSS Decoder Software?
Colin9690
County 21
APE282018
I have a PRO-93 which can't decode PL/DPL. Is there any free software that will decode the PL/DPL that is being received by the scanner?
Thanks :D ,
Joseph11
I also need an application that does this, I found that WinTone only works on Windows 9x. The MS-DOS decoder doesn't work on XP either.
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi Joseph and all,
"The MS-DOS decoder doesn't work on XP either."
Please explain. XP emulates every version of Windows behind it and does a bangup job on my V3.11 and DOS apps as well as iTunes which is Apple/Mac. The good part about it is you don't have to open a DOS window, everything just runs.
Joseph11
Any NT based OS doesn't have real DOS in it, it makes a Virtual Enviroment for DOS and 16-bit applications. I had WinTone running pretty good on an older computer from 1998 running Windows XP, but on a newer one from 2004 it won't run at all. Since my sound card is so new, I doubt I can find any DOS drivers for it so that rules out the DOS program.
EDIT: Actually, on the newer XP computer, it does run, but it doesn't decode properly and crashes when being used.
