Custom Firmware for Encryption
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Intriguing, but I can’t get over how the radios follow the access keys when they are changed.
Access keys?
The agency using the encryption does routine “handshakes” with each radio when they are attempting a transmission, each unit being registered with the controller.
ANY radio, regardless of encryption being used or not has to register and affiliate to the system.
The 'handshake' isnt a hand shake when you PTT, it is a channel request. If everything is okay, the system will grant a voice channel.
If the unit in question is not registered with the controller it is not recognized and therefore does not get the key needed to communicate.
That's not how it works at all. Encryption keys can be loaded by a key loader, with out a radio ever registering, or affiliating to a trunk system. This is how its done with conventional systems that use encryption.
Unless the radio keys are out of date, and needs to be re-keyed(this required the feature to be active in the radios, and a KMF active and installed on the system) there is no key loading when the radio affiliates.
Even if you found a lost or stolen portable radio belonging to the agency, if it’s reported as lost or stolen, the system will locate said radio using GPS and it is recovered.
That's not how it works. While a system can be configured to allow this to happen, It isn't the normal.
even if the radio is turned off.
You watch waaaay too much TV. That's not how it works. At all.
If they can do that it means they can disable the radio remotely
Correct. They can.
in addition to locating it.
IF, and it's a big IF, the system has been configured to make use of location data.
So, even with a key, what do you do when the key is changed?
Then you need the new key. Duh.
It’s my understanding they can set up the changing of keys anytime they choose,
To a point. First a new key set needs to be created and made available in the KMF(IF OTAR is an available feature AND the radios have that feature active), then every radio needs to be re-keyed with the new key set. Then after, the consoles all need to be rekeyed as well. Once that is done, then the new keys can be used.
routinely changing keys on a daily basis, up to the minute basis or only when the need arises.
Thats not how it works at all. Changing keys doesn't happen daily, and absolutely doesn't happen by the minute.
If keys are changed, it would more likely be monthly, or a longer interval than that. Sometimes they are never changed. Depends how seriously the agency takes their comms security.
But I am by no means an expert
No need to tell us, it's very apparent you don't know what you are talking about.
where encryption techniques are concerned and accept there are sensitive and proprietary reasons for its use, where the information conveyed is not for my ears so I don’t bother programming encrypted systems period.
Nothing any first responder agency says on the radio is for any unauthorized listener(anyone that isn't a member or emotes of said agency is an unauthorized listener) to listen to.
However, I do believe there are times it’s a needed mode and time where it’s not.
It's needed 100% of the time.
a727469
Maine
Boy, 4 pages and we are right back at the start.
Yes, a piece of software provides the means but not the result(need key)
The legalities of the means seem fine.
The results of using a key if not authorized are not fine(or legal?).
kayn1n32008
Sector 001
Always call BS on any claim of decrypting up to date systems.
Well keep believing that.
DES is a dead encryption method. Quite old and outdated.
DES uses a 56 bit key.. you are correct. DES is long out dated.
ADP/EP/ARC4 uses a 40bit key.
it's a 16 it shorter key than DES. It is an incredibly weak cipher, and offers zero security. Modern computers can easily brute force a 40bit key. They can easily brute force a 56bit key.
AES 256 is the usual standard now.
Except, AES isn't really prevalent in NA in Motorola DMR subscribers.
Many agencies are only using APD on P25 systems.
Also used with financial web site certificates and any other sites wanting the highest security between your web browser and the web site. AES 128 is possibly breakable with numerous super computers and enough time. But AES 256 currently is not. Look at the site cert for your bank's web site. It will show AES 128 GCM or AES 256 GCM. My credit union site is AES 128, but fidelty.com wher I invest is AES 256.
Okay?
Currently there are no computers that can break AES 256.
For now.
The amount of time needed is virtually infinite.
That is going to change. A lot sooner than you think.
n3617400
MOON 2112
And I still can't get it to work on ADP and now AES256. It does remove the band restrictions, but that doesn't really do me any good.
Set only the "Frequency" checkbox and specify the frequency and key. The rest of the checkboxes are unchecked. That's usually the problem. Well it only works with P25 phase 1 ADP, P25 AES256 in plans.
Firebuff66
CT
Figured out my issue (operator error) and it worked on P25 ADP as well as DMR basic privacy (that's all I tried).
Took me a few also :) I have no idea why people are getting so uptight about this, Like was said above, it the same as having a Unication.
If you don't have the key you are not going to hear anything and the Unication/Motorola/Harris/Uniden/Icom/BK and on will all decode encryption IF you have the key...They wont find it for you
sflmonitor
South Florida
If I wanted to program this for a P25 DES trunked system, do I just have to set each frequency and key individually or does programming this to a trunked system require a different method. BTW, it worked fine on a conventional, P25 DES channel.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
For all the people that have asked for Uniden scanners to NOT mute encryption this FW will let you do that. I've not tried it, but conceivably you could set up a P25 OFT and log the RID's of encrypted traffic.
Ubbe
Stockholm, Sweden
When scanning stops on a frequency it looks up the frequency in the CFT file and apply any key if it finds it. It can use any other indicators as a TG and so on but if the frequency are always encrypted its easier to only enter the frequency in the file.
As encrypted signals do not force a scan it stays on the frequency and it seems to have made non encrypted signals to work better and not skip transmissions that it earlier though where encrypted, due to bad decoding quality. But I believe that the false decode of RAS, that disables error correction, are the real source of that problem.
/Ubbe
upstatesc
For those who have tried it, would this firmware work with NXDN Trunked systems or just single channel NXDN? Assuming you know the "key" of course. I've read the documentation, but it isn't clear on Trunking outside of DMR.
KevinC
Encryption
Super Moderator
I've not tried trunked NXDN. I suggest installing it and give it a try, you can always go back to the fully factory if it doesn't work.
And I neither endorse or condone this FW, use at your own risk.
n3617400
MOON 2112
The custom firmware doesn't care what system is used, it activates decryption when a voice channel appears. A special feature when configuring trunked systems is that each voice channel of the system must be configured in the CFT custom firmware configuration program.
Echo4Thirty
Colorado Springs, CO
It will mute it on encrypted P25 Phase I. Phase II TGs do not display keys or mute. The author acknowleges that Phase II is not currently supported. I am not sure about DMR or NXDN.
