Dane county ambulance numbering
biglaz
Blue Mounds, WI
Does anyone know if there's a method to the ambulance numbering in Dane county? At first I thought it might be coordinated with the PD unit numbering, but it seems that's not the case.
Anyone have any thoughts?
CPFD25
Cross Plains WI
re. Dane county ambulance numbering
I personally don’t know what or why the method is the way it is, but it seems that the numbers are relative to where the municipality is in the county west being lower numbers to higher number in the east; all with the exception of Waunakee (Rescues 24&26) and the city of Madison (Rescues 1-8). And for the most part all the rescues are even numbers, with a few exceptions. And there really is no correlation between the police numbering and the ambulance numbers. So as for the overall county like I said Waunakee is the oddball of what I believe to be the system of basically left to right, or west to east. Mazomanie being the furthest west being rescue 28 and then Cambridge being the last with rescue 92. Also Dane county has a backup ambulance that can be used by any of the Dane County services, for use if an ambulance is out of service for whatever reason, or special events. Typically they will go by whatever ambulances number that it is temporarily replacing or if it is being used for a special even as an extra (iron man) it will go by Dane County Rescue 30.
I am a driver for Cross Plains and a Firefighter for Cross Plains also. And I really don’t know of how our numbering is decided but that’s the best I can say or assume, but if that helps you out then that’s what I know.
ffemtbland
not that i know of - ff/emt monona fd. we are r62. i know the city of madison has a few of their own backup rescues ... they normally just call them the same number of the rescue they are replacing - although if you listened to the city radio yesterday, they had r64 on standbay at mifflin for the block party.
lars
